Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Create form with Ilogic
2 REPLIES 2
tomas_wiklund
241 Views, 2 Replies
Hi!
I have form created with Ilogic. The Form contains four radio buttons.
My goal is to change a custom property when user change radio button.
I've commented out the problem in line 76.
Does someone have any ideas how to do this?
Big shout out for the main code @WCrihfield
AddReference "System.Drawing"
Imports System.ComponentModel
Imports System.Drawing
Imports System.Windows.Forms
Public Class WinForm
	Inherits System.Windows.Forms.Form
	'Lista med olika tillverkningsmetoder
    Private wordList As List(Of String) = New List(Of String) From {"Laserskuren", "Svarvad/Fräst", "3D-printad", "Inköpsdetalj"}
	'Deklarerar Dictionary för att lagra Radio Buttons
    Private radioButtons As Dictionary(Of String, RadioButton) = New Dictionary(Of String, RadioButton)
	'Allmäna deklarationer för att använda i Subs & Functions
	Public oLargerFont As System.Drawing.Font = New Font("Arial", 10)
	Public Sub New() 'creates the new instance
		'Formuläret
		Dim oForm As System.Windows.Forms.Form = Me
		With oForm
			.FormBorderStyle = FormBorderStyle.FixedToolWindow
			.StartPosition = FormStartPosition.CenterScreen
			.Width = 300
			.Height = 300
			.TopMost = True
			.Font = oLargerFont
			.Text = "Windows Form"
			.Name = "Windows Form"
			.ShowInTaskbar = False
		End With
		'AddHandler oForm.FormClosing, AddressOf oForm_FormClosing
		'Knapp
		Dim oButton1 As New Button()
		With oButton1
			.Text = "TEST ME"
			.Top = 25
			.Left = 25
			.Enabled = True
			.AutoSize = True
		End With
		oForm.Controls.Add(oButton1)
		AddHandler oButton1.Click, AddressOf oButton1_Click
		'Skapa radio-knappar dynamiskt baserat på ordlistan
        For Each word In wordList
            Dim radioButton As New RadioButton()
            radioButton.Text = word
            radioButton.Top = oButton1.Bottom + 25 + wordList.IndexOf(word) * 30
            radioButton.Left = 25
            radioButton.AutoSize = True
            radioButtons.Add(word, radioButton)
            oForm.Controls.Add(radioButton)
            AddHandler radioButton.CheckedChanged, AddressOf RadioButton_CheckedChanged
        Next
	End Sub
	'This is the end of the main Sub that defines the Form
	Private Sub oForm_FormClosing(ByVal oSender As Object, ByVal oFormCloseEvents As FormClosingEventArgs)
		'oSender is a Form
		If MsgBox("Are you sure you want to close this Form?",vbYesNo+vbQuestion, "CLOSE") = vbYes Then
		Else
			oFormCloseEvents.Cancel = True
		End If
	End Sub
	Private Sub oButton1_Click(ByVal oSender As System.Object, ByVal oEventArgs As System.EventArgs)
		MsgBox("You just clicked the [" & oSender.Text & "] button.", vbOKOnly + vbInformation, "EVENT FEEDBACK")
	End Sub
	Public Sub RadioButton_CheckedChanged(sender As Object, e As EventArgs)
		Dim selectedRadioButton As RadioButton = DirectCast(sender, RadioButton)
		'iProperties.Value("Custom", "ManufacturingMethod") = selectedRadioButton.Text
End Sub
	' Method to initialize the state of radio buttons based on ManufacturingMethod iProperty
    Public Sub InitializeRadioButtons(ManufacturingMethod As String)
        ' Set the initial state of the radio buttons based on the ManufacturingMethod iProperty
        'Dim manufacturingMethod As String = iProperties.Value("Custom", "ManufacturingMethod")
        If wordList.Contains(ManufacturingMethod) Then
            radioButtons(ManufacturingMethod).Checked = True
        End If
    End Sub
End Class
'This is the code that actually shows/runs the Form
Public Class RunMyForm
	Private Sub Main()
		' Create an instance of WinForm and pass iLogicVb
		Dim oMyForm As New WinForm()
		'this visibly launches the form
		oMyForm.Show
		Dim ManufacturingMethod As String = iProperties.Value("Custom", "ManufacturingMethod")
		' Initialize the state of radio buttons based on ManufacturingMethod iProperty
		oMyForm.InitializeRadioButtons(ManufacturingMethod)
	End Sub
End Class
2 REPLIES 2
WCrihfield
in reply to: tomas_wiklund
Hi @tomas_wiklund.  It looks to me like you simply can not use that "iProperties.Value()" snippet within any 'other' Class, other than in the 'original' Class, because that is where the 'iProperties' variable is declared.  I moved your short Class just for running the form to the top of the code, then removed the Class & End Class lined from around it, so that it would adapt the 'original' Class that iLogic created for us in the background, named "ThisRule".  That change enabled your 'iProperties.Value' line to work within that block of code.  Then I changed your 'New' Sub routine, within the form Class, to accept an input parameter.  This could be done multiple ways, but I chose to pass a Document object into it, because you appear to want to modify the custom iProperties of that Document.  Try these modifications.  The modified code is attached as a text file.
Wesley Crihfield
(Not an Autodesk Employee)
tomas_wiklund
in reply to: WCrihfield
Elegant and working code!
With a little help from @Anonymous I got it working with code from this: https://forums.autodesk.com/t5/inventor-programming-ilogic/adding-custom-iproperties-to-idw-ussing-the-vb-net-inventor-api/td-p/6359859
Thanks both of you!
