Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Create dimension lines in the assembly view of the drawing using points or elements of parts within the assembly.
3 REPLIES 3
ysbaodnj
192 Views, 3 Replies
I would like to create code that automatically adds dimensions to assembly views in a drawing.
I would like to display in the assembly view using points or entities that exist in the part.
The code below completes including the part's points in the assembly view. I want to use this to display dimension lines. How do I do this? Also, please let me know how I should modify the code to use non-point entities.
Sub main()
    Dim oSheet As Sheet = ThisDoc.Document.ActiveSheet
    Dim oView As DrawingView = ActiveSheet.View("BaseView1").View
    Dim oDoc As Document = oView.ReferencedDocumentDescriptor.ReferencedDocument
    Dim silo As Document
    silo = oDoc.ReferencedDocuments.Item(9) 'hardcoded for the part I need
    Dim oWP1 As Inventor.WorkPoint = silo.componentdefinition.workpoints.item("DPA1-1")
    Dim oWPP1 As WorkPointProxy
    Dim oAssDoc As AssemblyDocument = oDoc
	Dim oOccs As ComponentOccurrences
	oOccs = oAssDoc.ComponentDefinition.Occurrences
	Dim oOcc As ComponentOccurrence
	For Each oOcc In oOccs
		'Chops off ":####" at the End Of occurrance display name
		Dim oOccName As String
		oOccName = oOcc.Name
		Dim trimCount As Integer
		trimCount = oOccName.Length - oOccName.LastIndexOf(":")
		oOccName = Left(oOccName, (oOccName.Length - trimCount))
		If oOccName = silo.DisplayName
			oOcc.CreateGeometryProxy(oWP1, oWPP1)
			oView.SetIncludeStatus(oWPP1, True)
		End If
	Next
End Sub
3 REPLIES 3
JelteDeJong
in reply to: ysbaodnj
You might want to look at the feature 'Assign name' to face.
You can use those names in your ilogic code in your drawing. Adding dimension can be as simple as this:
Dim Sheet_1 = ThisDrawing.Sheets.ItemByName("Sheet1:1")
Dim VIEW1 = Sheet_1.DrawingViews.ItemByName("VIEW1")
Dim namedGeometry1 = VIEW1.GetIntent(MakePath("SubAssem1:1", "Part2:1"), "Face1")
Dim namedGeometry2 = VIEW1.GetIntent(MakePath("SubAssem1:1", "Part2:1"), "Face2")
Dim genDims = Sheet_1.DrawingDimensions.GeneralDimensions
ThisDrawing.BeginManage()
	Dim linDim1 = genDims.AddLinear("Dimension 1", VIEW1.SheetPoint(-0.1, 0.5), namedGeometry1)
	Dim linDim2 = genDims.AddLinear("Dimension 2", VIEW1.SheetPoint(1.1, 0.5), namedGeometry2)
	Dim linDim3 = genDims.AddLinear("Dimension 3", VIEW1.SheetPoint(0.5, 1.2), namedGeometry1, namedGeometry2)
ThisDrawing.EndManage()
Maybe this YouTube movie is interesting to you: https://www.youtube.com/watch?v=9C3c6OVsU1U
On a side note, sometimes dimension texts are placed in an unexpected place. The reason and the workaround are a bit to much to discuss here. However, I proposed a solution/idea to Autodesk. In that proposal/idea, you can find all the information on the topic. (And it would be cool if you voted for the idea/proposal 😉
Jelte de Jong
Blog: hjalte.nl - github.com
ysbaodnj
"Assign name" cannot be defined in an assembly. Because they are defined only in the part, you need code to create dimensions by defining them in the part and importing them from the assembly view...
jelte.de.jong
indeed the "Assign name" method only works in parts. But by using the iLogic command "MakePath" you can get the intent of a Faces in a part in an assemlby. Have a look at this line:
  The named face here is in the "SubAssem1:1" and "Part2:1"
But if you really want to define your faces in your assembly (but want to use most of the default iLogic commands) then have a look at my blog series on this topic. (I would not recommend doing this as a beginner but maybe it works for you.) This series will let you recreate the functions iLogic has but then for assemblies.
