Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Create a plane and mirror solid
1 REPLY 1
1000 Views, 1 Reply
Hello
Can anyone help me to create a plane and mirror a solid?
I am planning to have the following workflow:
Plane creation:
Through the z-axis and at an angle of 7,5° to the XZ-Plane
Naming the plane - Mirror Plane
Turning off the plane visibility
Mirror solid:
Add mirrored solid to the existing solid
Here is a sample ao the code...
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
Dim oCol As ObjectCollection
oCol = ThisApplication.TransientObjects.CreateObjectCollection
'This does not work...
oCol.Add(oDoc.ComponentDefinition.SurfaceBodies(1))
'Here I want to create a new plane
Dim oPlane As WorkPlane
oPlane = oDoc.ComponentDefinition.WorkPlanes(1)
Dim oMirror As MirrorFeature
oMirror = oDoc.ComponentDefinition.Features.MirrorFeatures.Add(oCol, oPlane, False, kOptimizedCompute)
I have also attached a simplified part file where the code has been copied inti the iLogic browser
Best regards
Kari
1 REPLY 1
It was solved like this (this code was used in iLogic):
Sub Main()
Dim invApp As Inventor.Application = Nothing
invApp = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
' Get the part document.
Dim partDoc As Inventor.PartDocument
partDoc = invApp.ActiveDocument
'Get the part component definition
Dim oPartDef As Inventor.PartComponentDefinition
oPartDef = invApp.ActiveDocument.ComponentDefinition
' Get the X-Z-Plane work plane.
Dim oxzPlane As Inventor.WorkPlane
oxzPlane = oPartDef.WorkPlanes.Item(2)
'Get the Z-Axis
Dim ozAxis As Inventor.WorkAxis
ozAxis = oPartDef.WorkAxes.Item(3)
'Create the mirror plane (15° is sat as default)
Dim oPlane4 As Inventor.WorkPlane
oPlane4 = oPartDef.WorkPlanes.AddByLinePlaneAndAngle(ozAxis, oxzPlane, 15 / 2 / 180 * System.Math.PI)
'Turn off the visibility of the mirror plane
oPlane4.Visible = False
'Get the object collection
Dim oCol As Inventor.ObjectCollection
oCol = invApp.TransientObjects.CreateObjectCollection
oCol.Add(partDoc.ComponentDefinition.SurfaceBodies(1))
'Mirror the feature
Dim oMirror As Inventor.MirrorFeature
oMirror = partDoc.ComponentDefinition.Features.MirrorFeatures.Add(oCol, oPlane4, False)
'This can be activated if the mirrored feature is to
'be a new solid
'oMirror.NewBodyOperation = True
ThisDoc.Save
End Sub
Technology Administrators
