Create a new Inventor DWG drawing using VB.NET
5 REPLIES 5
2208 Views, 5 Replies
Hello.
I'm trying to create a new DWG file in Inventor.
In the Inventor options I changed the default file type of drawing, but when I add a new document using the Add method from the Documents collection, always creates a file of type IDW.
I tried to force the option from code, but I get the same result.
I am using VB.net 2008 and Inventor 2010, this is the code:
InvApp = InventorGet()
InvApp.Visible = True
InvApp.DrawingOptions.DefaultDrawingFileType = DefaultDrawingFileTypeEnum.kDWGDefaultDrawingFileType
InvDoc = InvApp.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject)
Any ideas? Thanks in advance
Tags (2)
5 REPLIES 5
Dennis.Ossadnik
Hi jgaston,
you could use it like that and specify the template file:
Dim InvDoc As Document
Set InvDoc = InvApp.Documents.Add(kDrawingDocumentObject, "C:\Templates\Norm.dwg", True)
Hope, this helps.
Dennis Ossadnik
Senior Technical Support Specialist
in reply to: Dennis.Ossadnik
Thanks Dennis, but hoped to use the default template and not have to deal with code to manage the routes.
If I understand, the help of the API says the method should work this way.
Regards
Dennis.Ossadnik
Hi jgaston
Here is an exaple how you can use the standard templates:
first set the option: DrawingOptions.DefaultDrawingFileType = kDWGDefaultDrawingFileType
then get your template: FileManager.GetTemplateFile(kDrawingDocumentObject, kDefaultSystemOfMeasure, kDefault_DraftingStandard, "{BBF9FDF1-52DC-11D0-8C04-0800090BE8EC}")
use this template in the way i mentioned:
Documents.Add(kDrawingDocumentObject, TemplateNameDWG, True)
Example:
This code will add two new drawing douments to inventor. One dwg, one idw.
Dim InvApp As Application
Set InvApp = ThisApplication
'Get name of DWG Tamplate
InvApp.DrawingOptions.DefaultDrawingFileType = kDWGDefaultDrawingFileType
Dim TemplateNameDWG As String
TemplateNameDWG = InvApp.FileManager.GetTemplateFile(kDrawingDocumentObject, kDefaultSystemOfMeasure, kDefault_DraftingStandard, "{BBF9FDF1-52DC-11D0-8C04-0800090BE8EC}")
'Get name of idw template
InvApp.DrawingOptions.DefaultDrawingFileType = kIDWDefaultDrawingFileType
Dim TemplateNameIDW As String
TemplateNameIDW = InvApp.FileManager.GetTemplateFile(kDrawingDocumentObject, kDefaultSystemOfMeasure, kDefault_DraftingStandard, "{BBF9FDF1-52DC-11D0-8C04-0800090BE8EC}")
'New DWG
Dim oDocDWG As Document
Set oDocDWG = InvApp.Documents.Add(kDrawingDocumentObject, TemplateNameDWG, True)
'New IDW
Dim oDocIdw As Document
Set oDocIdw = InvApp.Documents.Add(kDrawingDocumentObject, TemplateNameIDW, True)
I hope this works for you.
Dennis Ossadnik
Thank you very much Denis
I manage with this.
Just one question, the GUID "{BBF9FDF1-52DC-11D0-8C04-0800090BE8EC}" what type of document referred to? where I can find a list of GUID's valid for this function?
Best regards and thank you very much again.
Josh_Hunt
Hi @Anonymous and @Dennis.Ossadnik
A decade later and this is still a bug if the documentation https://help.autodesk.com/view/INVNTOR/2020/ENU/?guid=GUID-66A32241-D9C0-4E9D-B6D1-F4A9DA1F69F9 is correct.
Thank you for the workaround. However I now have to 'clean' the document of all Drawing Resources and styles before I can build from scratch.
BACKGROUND: I have a corrupt DWG template and I am trying to rebuild it using API to transfer all the content over. Not simple but possible.
Josh Hunt
