Hi...
I want to count visible selected type of drawing curve segment by any selectset is activate in drawing view...
I get difficulties to get the drawing view name (ex: "VIEW16") by activate selectset a drawing curve segment in that view...
The counting seem not found the correct answer... as below example... the part is actually having 2 size of fillet...
"Fillet1" x3 and Fillet2" x2 ... "Fillet1" visible count should be 2 in "VIWE16" but the result only count 1...
VBa.
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
Dim oSSet As SelectSet
Set oSSet = oDrawDoc.SelectSet
Dim oDwgCurveSegment As DrawingCurveSegment
Dim oSheet As Sheet
Set oSheet = oDrawDoc.ActiveSheet
Dim oView As DrawingView
Set oView = oSheet.DrawingViews.Item(1)
Dim i As Integer
For i = 1 To oView.DrawingCurves.Count
If oView.Name = "VIEW16" ThenFor Each oDwgCurveSegment In oView.DrawingCurves.Item(i).Segments
If oDwgCurveSegment.GeometryType = kCircularArcCurve2d Then
i = i + 1
MsgBox "kCircularArcCurve2d[" & i & "]"
End If
Next
End If
Solved by HideoYamada. Go to Solution.
I don't understand exactly what you want to do, but I have just rewritten your code.
Option Explicit Sub test() Dim oDrawDoc As DrawingDocument Set oDrawDoc = ThisApplication.ActiveDocument Dim oSSet As SelectSet Set oSSet = oDrawDoc.SelectSet Dim oDwgCurveSegment As DrawingCurveSegment Dim oSheet As Sheet Set oSheet = oDrawDoc.ActiveSheet Dim oView As DrawingView Set oView = oSheet.DrawingViews.Item(1) If oView.Name = "VIEW16" Then Dim i As Integer Dim oDrawingCurve As DrawingCurve For Each oDrawingCurve In oView.DrawingCurves For Each oDwgCurveSegment In oDrawingCurve.Segments If oDwgCurveSegment.GeometryType = kCircularArcCurve2d Then i = i + 1 MsgBox "kCircularArcCurve2d[" & i & "]" End If Next oDwgCurveSegment Next oDrawingCurve End If End Sub
Has this code approached what you want to do?
Hideo Yamada
Hi…
Please use my e-mail for this conversation…
The code is for my testing to approach what I actually need…
[ I need to count the visible “Fillet?” by one of it curve segments selectset in it view (ex:VIEW16)… To get the name VIEW16 by curve segment selectset also I still struggle and not yet figure out how…]
@Anonymous wrote:Please use my e-mail for this conversation…
O.K. Send the mail or private message to me freely.
Sub test2() Dim oDrawingCurveSegment As DrawingCurveSegment Dim oDrawingView As DrawingView Set oDrawingCurveSegment = ThisApplication.ActiveDocument.SelectSet(1) Set oDrawingView = oDrawingCurveSegment.Parent.Parent Debug.Print oDrawingView.Name End Sub
The parent of the parent of the DrawingCurveSegment is DrawingView.
Hideo Yamada
I manage to get the drawing view name as your suggest... but I still having error for below sample to get the counting result as I need ...
Public Sub FilletLeader()
Dim oSheet As Sheet
Dim oFeatureName As String
Dim oFace As Face
Dim i As Integer
Dim RadiusDim As RadiusGeneralDimension
Set RadiusDim = oSSet(1)
Set oView = RadiusDim.Intent.Geometry.Parent
Set oDwgCurveSegment = RadiusDim.Intent.Geometry.Segments(1)
Set oFace = RadiusDim.Intent.Geometry.ModelGeometry.Faces(2)
oFeatureName = oFace.CreatedByFeature.Name
If oFace.CreatedByFeature.Faces.Item.CreatedByFeature.Name = oFeatureName Then
i = i + 1
MsgBox oFeatureName & " = " & i
End If
Next
This code will count the fillet curves that the feature is selected by the radius dimension and are shown as an arc in the view.
Public Sub FilletLeader() ' ' Check the condition and initialize the values. ' If Not TypeOf ThisApplication.ActiveDocument Is DrawingDocument Then Exit Sub Dim oDrawDoc As DrawingDocument: Set oDrawDoc = ThisApplication.ActiveDocument Dim oSheet As Sheet: Set oSheet = oDrawDoc.ActiveSheet If oSheet Is Nothing Then Exit Sub Dim oSSet As SelectSet: Set oSSet = oDrawDoc.SelectSet If oSSet.count < 1 Then Exit Sub If Not TypeOf oSSet(1) Is RadiusGeneralDimension Then Exit Sub Dim oRadiusDim As RadiusGeneralDimension: Set oRadiusDim = oSSet(1) Dim oFilletFeature As FilletFeature Dim oFace As Face For Each oFace In oRadiusDim.Intent.Geometry.ModelGeometry.Faces If TypeOf oFace.CreatedByFeature Is FilletFeature Then Set oFilletFeature = oFace.CreatedByFeature Exit For End If Next oFace If oFilletFeature Is Nothing Then Exit Sub ' Debug.Print oFilletFeature.Name ' ' Prepare for counting the fillet edges ' Dim oView As DrawingView: Set oView = oRadiusDim.Intent.Geometry.Parent Dim NofFilletFaces As Integer NofFilletFaces = oFilletFeature.Faces.count Dim counted() As Boolean: ReDim counted(NofFilletFaces) Dim count As Integer Dim i As Integer ' ' Count fillet edges. ' Dim oDwgCurve As DrawingCurve For Each oDwgCurve In oView.DrawingCurves ' Only count if the edge is shown as an arc. If TypeOf oDwgCurve.Segments(1).Geometry Is Arc2d Then For Each oFace In oDwgCurve.ModelGeometry.Faces If oFace.CreatedByFeature Is oFilletFeature Then ' Only count one time for each fillet face. For i = 1 To NofFilletFaces If oFilletFeature.Faces(i) = oFace And (Not counted(i)) Then counted(i) = True count = count + 1 Exit For End If Next i End If If count = NofFilletFaces Then Exit For Next oFace End If If count = NofFilletFaces Then Exit For Next oDwgCurve Debug.Print count End Sub
I think that this code works as you want.
Hideo Yamada
Hi... I try the same method for count the "Chamfer1" in a View.... but can't figure out the curve segment like Fillet... Anything you can do about it...
