Hello friends,
Every time I make a revision for a drawing, there are many revmarks marked. I have to count it manually and sometimes I miss it. I am thinking about ilogic or vba which can count the number of revmarks in the sketch symbol. Please help me. Thank you.
Solved by WCrihfield. Go to Solution.
Hi @tonythm. I am not sure I understand the situation fully yet. Are you saying that you use a SketchedSymbol instead of a regular revision tag every time you mark something as being revised? And are you saying that the same, pre-existing SketchedSymbol on the sheet from the previous revision gets edited each time to add more geometry/text into that same SketchedSymbol for the next revision level, and you want code that can find this one SketchedSymbol, inspect the sketch defining that SketchedSymbol, and somehow determine how many of those internal revision symbols are within it? This sounds very complicated...unless I am not understanding you correctly.
Or...are you using normal revision tags, and just want some code to count how many of those there are within your drawing? Or...are you using a SketchedSymbol instead of a normal revision tag, but there is only one revision tag type spec within each SketchedSymbol, and you want to count how many of these special SketchSymbol objects are in your drawing that represent these revision tag alternatives?
Please explain as clearly as possible, and with as much detail as possible.
Wesley Crihfield
(Not an Autodesk Employee)
Thank you for your interest.
I am using SketchedSymbol instead of the usual revision tag,
In SketchedSymbol I use the Edit Property Field function to fill in revision A or B or C... and I want to count how many of these SketchSymbol objects are in the drawing.
Suppose, my current drawing is revision "B" and I am working on revision "C", then the drawing already has SketchedSymbols "B", how do I add SketchedSymbols "C" to know how many SketchedSymbols "C" there are, and each time I want to know how many SketchedSymbols "..." were recently added.
I just started using ilogic so I may not understand them very well.
Sub Main()
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDoc.ActiveSheet
Dim oSymbol As SketchedSymbolDefinition
Dim REVMARK As String
Dim sData As String
Dim oCountB As Integer
Dim oCountC As Integer
For Each oSymbol In oDoc.SketchedSymbolDefinitions.SketchedSymbolDefinitionLibraries
If oSymbol.Name = "REVMARK" Then
sData = oSymbol.GetResultText(oSymbol.Definition.Sketch.TextBoxes.Item(1))
If sData = "B" Then
oCountB = oDoc.SketchedSymbolDefinitions.Count
End If
End If
Next
MessageBox.Show(oCountB, "QUANTITY")
End Sub
Hi @WCrihfield
I changed ilogic a bit, it displays all SketchedSymbols including SketchedSymbol revisions and SketchedSymbol others. How do I know how many latest SketchedSymbol revisions there are?
Sub Main()
Dim oSheet As Sheet
Dim sData As String
For Each oSymbol In oSheet.SketchedSymbols
If sData = "B" Then
oCountB = oSheet.SketchedSymbols.Count
End If
End If
'MessageBox.Show(oCountB, "QUANTITY")
Next
End Sub
Hi @tonythm. Here is another example iLogic rule you can try for this task. Not really sure what type of output / results you are looking for, so I am must using MsgBox messages to show results. We could also write the results to the iLogic Log window, if you wanted.
Sub Main
Dim oDDoc As DrawingDocument = TryCast(ThisDoc.Document, Inventor.DrawingDocument)
If oDDoc Is Nothing Then Return
Dim oSSDefs As SketchedSymbolDefinitions = oDDoc.SketchedSymbolDefinitions
If oSSDefs.Count = 0 Then Return
Dim oSSDef As SketchedSymbolDefinition
Try : oSSDef = oSSDefs.Item("REVMARK") : Catch : End Try
If oSSDef Is Nothing Then
MsgBox("SketchedSymbolDefinition Named 'REVMARK' Not Found!", vbCritical, "iLogic")
Return
End If
'assuming that it only has 1 TextBox, and that one is for a 'Prompted Entry'
Dim oTB1 As Inventor.TextBox = oSSDef.Sketch.TextBoxes.Item(1)
Dim oSheets As Inventor.Sheets = oDDoc.Sheets
Dim oDict As New Dictionary(Of String, Integer)
For Each oSheet As Inventor.Sheet In oSheets
Dim oSSs As SketchedSymbols = oSheet.SketchedSymbols
If oSSs.Count = 0 Then Continue For
For Each oSS As SketchedSymbol In oSSs
If oSS.Definition Is oSSDef Then
Dim sResult As String = oSS.GetResultText(oTB1)
If oDict.ContainsKey(sResult) Then
oDict.Item(sResult) = oDict.Item(sResult) + 1
Else
oDict.Add(sResult, 1)
End If
End If
Next 'oSS
Next 'oSheet
If oDict.Count = 0 Then
MsgBox("No Rev SketchedSymbols Found In Drawing.", vbInformation, "iLogic")
Else
For Each oEntry In oDict
MsgBox("There were " & oEntry.Value.ToString & " instances for Rev " & oEntry.Key)
Next 'oEntry
End If
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
