I would like to add three columns in my BOM that should do the following:
1. The cost of material done using the formula (Percentage area X Total cost of material)
2. The cost of powder coating of material using the formula (surface area of material X cost of powder coating per square meter)
3. Putting cost of parts in the content center for example bolts and nuts
Solved by k14348. Go to Solution.
you should use excel sheet for this calculation. You should have one standard excel template where all formulas added in cells. Screenshot attached. If u want in the inventor bom itself then u have to run code.
Karth
