Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Copying Item QTY from Assembly BOM to a Part custom iproperties
7 REPLIES 7
Message 1 of 8
spanky
349 Views, 7 Replies
spanky
Is there a way to use iLogic to copy a value from the assembly BOM 'Item QTY', and paste it to each part in the assembly as a custom iproperty?
7 REPLIES 7
Message 2 of 8
A.Acheson
in reply to: spanky
A.Acheson
By looping through the BomView object ad each Bom Row you can achieve this.
Dim assyDoc As AssemblyDocument = ThisDoc.Document
Dim bom As BOM = assyDoc.ComponentDefinition.BOM
bom.PartsOnlyViewEnabled = True
Dim bView As BOMView = bom.BOMViews.Item("Parts Only")
For Each bRow As BOMRow In bView.BOMRows
	If bRow.ComponentDefinitions.Count > 1
		'MessageBox.Show("duplicate part #'s")
		Continue For
	Dim partDoc As PartDocument = bRow.ComponentDefinitions(1).Document
	If Not partDoc.IsModifiable Then Continue For
	' ilogic iProperty Method.
	Try
		Dim componentName As String = IO.Path.GetFileName(partDoc.FullFileName)
		iProperties.Value(componentName,"Custom", "TOTAL QTY") = bRow.ItemQuantity
	Catch
	End Try
'	' API PropertySets Method.
'	Dim totalQty As Inventor.Property
'	Try
'		totalQty = partDoc.PropertySets.Item(4).Item("TOTAL QTY")
'		totalQty.Value = bRow.ItemQuantity
'	Catch
'		totalQty = partDoc.PropertySets.Item(4).Add(bRow.ItemQuantity,"TOTAL QTY")
'	End Try
Next
Regards
Alan
		Continue For
	Try
	Catch
	End Try
'	Try
'	Catch
'	End Try
Next
Regards
Alan
Message 3 of 8
spanky
in reply to: A.Acheson
spanky
Any ideas? @A.Acheson
It gives me an error in Line 15.
Message 4 of 8
Curtis_Waguespack
in reply to: spanky
Curtis_Waguespack
Hi @spanky
It likely just tripped over a subassembly in your BOM
I think you can just change line 15
from this:
to this:
Dim partDoc As Document = bRow.ComponentDefinitions(1).Document
Hi @spanky
from this:
to this:
Message 5 of 8
GosponZ
in reply to: spanky
GosponZ
Try this one run in assembly.
doc = ThisDoc.Document
Dim oAssyDef As AssemblyComponentDefinition = doc.ComponentDefinition
Dim oBOM As BOM = oAssyDef.BOM
oBOM.PartsOnlyViewEnabled = True
Dim oBOMView As BOMView = oBOM.BOMViews.Item("Parts Only")
Dim oBOMRow As BOMRow
For Each oBOMRow In oBOMView.BOMRows
    'Set a reference to the primary ComponentDefinition of the row
    Dim oCompDef As ComponentDefinition
    oCompDef = oBOMRow.ComponentDefinitions.Item(1)
    Dim CompFullDocumentName As String = oCompDef.Document.FullDocumentName
    Dim CompFileNameOnly As String
    Dim index As Integer = CompFullDocumentName.LastIndexOf("\")
    CompFileNameOnly = CompFullDocumentName.Substring(index+1)
    'MessageBox.Show(CompFileNameOnly)
    Dim Qty As String
    Qty = oBOMRow.TotalQuantity
    iProperties.Value(CompFileNameOnly, "Custom", "PartQty") = Qty
Next
    Dim Qty As String
Next
Message 6 of 8
A.Acheson
Cheers Curtis,
I hadn't allowed for assemblies being inseparable and being in there which is why it tripped up on the part document declaration. The generic document declaration will allow both part documents and assembly document processing.
Regards
Alan
Cheers Curtis,
Regards
Alan
Message 7 of 8
spanky
spanky
Thank you!
Thank you!
Message 8 of 8
spanky
in reply to: GosponZ
spanky
This one worked also, but seems to have pulled the standard QTY data, versus the Item QTY. But thank you for the help also!
