I have an assembly that I created a form for. In that form I allowed the user to "Copy Design". I used this form in a couple of different places but recently I've got an error see the attached picture for the error message. I've done a little research and it seems that the "property set" it's looking for is the "custom" propety tab iproperties? If this is the case how do I get the code to recognize that the tab is actually there(it has been there the whole time) I don't know why it can't find the tab in iproperties.
I think that is going to work but now I'm getting the attached error. How do I fix it? here is my code I used your code in line 52:
Imports System Imports System.IO '[ ¸.•´¯`•.¸_¸.•´¯`•.¸||Copy Files To New Directory||¸.•´¯`•.¸_¸.•´¯`•.¸ 'Copies children files (parts, assemblies and drawings) to same folder (..\..\Drawings for .idw's) as the top assembly 'Notes: Turn debugMsgs to True for some simple messages that walk through some of the process. 'Version: V2.0.1 06/26/2013 '] Sub Main() '[=====Declarations===== Dim oDoc as Inventor.AssemblyDocument oDoc = ThisDoc.Document Dim debugMsgs as Boolean = True 'Set to true to display debugging messages. Currently only show messages from the drawing copy and replace portion of the rule. Dim prereqInfo As Boolean = True'Determines if the required info has been entered runCount = 0 ' Prevents the included code from running unless project and flow numbers are present, and it hasn't been copied to a new location yet If prereqInfo = True And Parameter("isCopied") = False Then Dim oFileMgr As FileManager Dim oAsmCompDef as AssemblyComponentDefinition oAsmCompDef = oDoc.ComponentDefinition cLocs.masterLoc = Parameter("masterLocation") & "MODELS\" oldDwgLocation = Parameter("masterLocation") & "DRAWINGS\" cLocs.newLoc = ThisDoc.Path cLocs.mLocLen = Len(cLocs.masterLoc) Call ThisApplication.FileManager.RefreshAllDocuments 'Call CreateFolders(masterLoc, newLoc) Dim oPS as PropertySet Try oPS = Document.PropertySets("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}") Catch Call CopyFiles(oDoc)', masterLoc, newLoc) 'Call the copy function on this document. It copies all of the referenced files into the same directory as oDoc. End Try ' Dim files As String ' oDoc.Save2 '[=====Copy Drawings Over===== Dim oProjNum As String = Parameter("projectNum") Dim oFlowNum as String = Parameter("flowNum") Dim oProjAbbr As String = Parameter("projectAbbr") Dim oProjRev As String = Parameter("projectRev") Dim oProjYear As String = Parameter("projectYear") Dim oProjSEQ As String = Parameter("projectSEQ") Dim oProjDes as String = Parameter("projectDesignation") Dim oDwgDoc as DrawingDocument Dim oPropDoc as Document Dim oNVM As NameValueMap oNVM = ThisApplication.TransientObjects.CreateNameValueMap 'oNVM.Add("DeferUpdates", True) Dim oFileDesc as FileDescriptor 'Loop through all files in the old drawing directory, check if they are .idw, copy them to the destination folder, then loop through all of the part/assembly references 'in the new drawings and determine the proper replacements 'oldDwgLocation = Parameter("dwgLocation") newDwgLocation = System.IO.Path.GetFullPath(ThisDoc.Path & "..\..\..\..\..\Drawings\") dwgFolder = System.IO.Directory.GetFiles(oldDwgLocation) a = 1 ' Loops through each file in the target directory and copies all of the files over to the new directory For Each targetFile As String In dwgFolder targetFileName = System.IO.Path.GetFileNameWithoutExtension(targetFile) 'Get file name of target file targetFileExt = System.IO.Path.GetExtension(targetFile) 'Get file extension of target file If debugMsgs Then MsgBox("Target Drawing File: " & targetFile) Dim isDrawing as Boolean = False 'Copies all of the drawing files in the folder over to the new folder If targetFileExt = ".idw" Then 'Replace the If targetFileName.Contains("XXXXXXXX-XX") Then newDwgName = targetFileName.Replace("XXXXXXXX-XX", oProjNum & oFlowNum & "-" & oProjSEQ) & targetFileExt ' Else If targetFileName.Contains("XXXXXXXX") Then ' newDwgName = targetFileName.Replace("XXXXXXXX", oProjNum & oFlowNum) & targetFileExt Else newDwgName = targetFileName & targetFileExt End If If Not System.IO.File.Exists(newDwgLocation & newDwgName) Then If debugMsgs Then MsgBox("COPYING: " & newDwgLocation & newDwgName) ' MsgBox("COPYING: " & newDwgLocation & newDwgName) Call ThisApplication.FileManager.CopyFile(targetFile, newDwgLocation & newDwgName)'If file doesn't already exist, copy file to new location ' isDrawing = True Else If debugMsgs Then MsgBox("Already Copied DRAWING: " & newDwgLocation & newDwgName) End If Dim fInfo As FileInfo = New FileInfo(newDwgLocation & newDwgName) If fInfo.IsReadOnly = True Then fInfo.IsReadOnly = False oDwgDoc = ThisApplication.Documents.OpenWithOptions(newDwgLocation & newDwgName, oNVM, False) 'Invisibly opens file to edit descriptions 'Loop through all of the referenced files in the drawing document, and look for the new filename by looking at all of the part/assembly files' OldName iProperties field For Each oFileDesc in oDwgDoc.File.ReferencedFileDescriptors 'For all of the file references in the drawing lookingFor = System.IO.Path.GetFileName(oFileDesc.FullFileName) 'Get the name only of the part we want to replace ' MsgBox("DRAWING: " & oFileDesc.FullFileName) If debugMsgs Then MsgBox("Looking For: " & lookingFor) ' MsgBox(ConvertToNew(lookingFor, oDoc)) If lookingFor <> iProperties.Value("Custom", "OldName") Then 'If the file being looked for is not this assembly, look for it in the other file references newFoundFile = ConvertToNew(lookingFor, oDoc) Else If debugMsgs Then MsgBox("This assembly is it") newFoundFile = ThisDoc.PathAndFileName(True) End If If debugMsgs Then MsgBox("Found it:" & newFoundFile) If newFoundFile <> "" Then 'If there is a file, then replace the current reference oFileDesc.ReplaceReference(newFoundFile) Else ' MsgBox("The file """ & lookingFor & """ referenced in drawing """ & oDoc.FullFileName & """ could not be found. Please repair this reference.") End If Next ' MsgBox(newDwgLocation & newDwgName) Else If debugMsgs Then MsgBox("Skipping " & targetFileName) Continue For End If oDwgDoc.Save oDwgDoc.Close If a = 3 Then Exit For a+=1 Next ']+++++\Copy Drawings Over+++++ Parameter("isCopied") = True 'Sets this to true to prevent rule from accidentally running again oDoc.Save2 ThisApplication.Documents.CloseAll(True) 'Close all background (read: not visible or interactable documents) showCompletionMessage = True End If 'End of the protective IF statement that keeps the rule running W/O project or flow numbers. This allows the design view representations to be repaired. '[ =====Set Design View Representation back to Default and Associative===== 'When replacing components, the design view representation may break causing previously hidden planes and other features to be shown. This section resets the 'design view to Associative and Default. The fileRepTypes list contains the types of files that cause an error because they have no Design View Representation, so 'the code skips those file types ' Dim oOcc as ComponentOccurrence ' Dim oAsmCompDefTwo As AssemblyComponentDefinition oAsmCompDefTwo = oDoc.ComponentDefinition For Each oOcc In oAsmCompDefTwo.Occurrences 'For every occurrence in the assembly, if the occurrence is an assembly, change its design veiw rep back to Default If oOcc.Definition.Type = ObjectTypeEnum.kAssemblyComponentDefinitionObject Then oOcc.SetDesignViewRepresentation("Default", "h", True) End If Next '] +++++/Design View+++++ '[ =====Display Completion Message Box===== 'Allows the Design View Rep to be fixed before the completion message box appears If Parameter("isCopied") = True And showCompletionMessage = True Then i = MessageBox.Show("Copy Design Complete.", "Completed", MessageBoxButtons.OK, MessageBoxIcon.Asterisk, MessageBoxDefaultButton.Button1) End If End Sub Public Class cLibraryLocations 'Declares oLibraryArray as a "global" variable accessable in the other Sub/Functions by using cLibraryLocations.oLibraryArray Public Shared oLibraryArray As New ArrayList End Class Public Class cLocs 'Declares oLibraryArray as a "global" variable accessable in the other Sub/Functions by using cLibraryLocations.oLibraryArray Public Shared masterLoc As String' = Parameter.Param("masterLocation") Public Shared newLoc as String' = "C:\Users\derek\Desktop\Save As Test\MODELS" Public Shared mLocLen As Integer '= Len(cLocs.masterLoc) Public Shared relPath End Class Private Function ConvertToNew(targetFile As String, containingDoc as Inventor.Document) As String 'Requires a filename, and an assembly document. Takes the old file name, usually from a drawing reference, loops through all of the files in 'the top level assembly and looks for the old file name in the new file's iProperties (Custom, OldName) then returns the name of the new file. Dim oFileDesc as FileDescriptor Dim oDocEnum as DocumentsEnumerator Dim availDoc as Document 'MsgBox("LOOKING FOR : " & targetFile) For Each oFileDesc in containingDoc.File.ReferencedFileDescriptors 'Look through all of the files in the assembly oldFilePath = System.IO.Path.GetDirectoryName(oFileDesc.FullFileName) oldFile = System.IO.Path.GetFileName(oFileDesc.FullFileName) ' MsgBox(oldFile) If oFileDesc.ReferencedFileType = 56327 Then Continue For 'Skip OLE (object linking and embedding) File References such as embedded Excels If cLibraryLocations.oLibraryArray.Contains(oldFilePath.ToUpper()) = True Then Continue For 'Skip library parts availDoc = oFileDesc.ReferencedFile.AvailableDocuments.Item(1) 'Set reference to the first document in the file (only one document is in a file 99% of the time) If debugMsgs Then MsgBox("iproperties: " & iProperties.Value(availDoc.DisplayName, "Custom", "OldName") & " TargetFile: " & targetFile) 'MsgBox(availDoc.DisplayName) If iProperties.Value(oldFile, "Custom", "OldName") = targetFile Then 'If the old filename matches the iProperty If debugMsgs Then MsgBox("iproperties: " & iProperties.Value(availDoc.DisplayName, "Custom", "OldName")) ConvertToNew = availDoc.File.FullFileName 'Set the reference to the new file End If 'If the document is a subassembly, run this function again on the subassembly to replace the references in that assembly If oFileDesc.ReferencedFileType = 56323 Then returnFile = ConvertToNew(targetFile, availDoc) If returnFile <> "" Then If debugMsgs Then MsgBox("assembly returned: " & returnFile ) ConvertToNew = returnFile Return ConvertToNew End If End If If ConvertToNew <> "" Then Return ConvertToNew End If Next End Function Private Sub CopyFiles(sourceAssy As Inventor.Document)', masterCopyLoc as String, newCopyLoc As String) 'This sub takes an assembly document that is passed to it, and copies all of the files referenced within that assembly to the directory that the assembly is saved in. This 'is meant to be used in cojunction with another rule that saves the assembly to a new location Dim projNum as String = Parameter("projectNum") Dim oFlowNum as String = Parameter("flowNum") Dim oProjAbbr As String = Parameter("projectAbbr") Dim oProjRev As String = Parameter("projectRev") Dim oProjYear As String = Parameter("projectYear") Dim oProjSEQ As String = Parameter("projectSEQ") Dim oProjDes as String = Parameter("projectDesignation") Dim oNewFiles as New ArrayList Dim oFileDesc as FileDescriptor Dim subDoc as Document 'An assembly found in the assembly Dim oCompOcc as ComponentOccurrence Dim oAsmCompDef as AssemblyComponentDefinition Dim oPartCompDef as PartComponentDefinition Dim oldFileNames as New ArrayList Dim availDoc as Document 'Dim masterLocation As String = Parameter("masterLocation") 'Dim mLocLen As Integer = Len(masterLocation) masterLocDirs = System.IO.Directory.GetDirectories(cLocs.masterLoc) ' Loop through each referenced file in the passed assembly, copy it over to the new project folder, replace the references in the ' files with the newly copied files, and run this function again on any assemblies found in the passed assembly testEnum = 1 For Each oFileDesc In sourceAssy.File.ReferencedFileDescriptors If oFileDesc.ReferencedFileType <> 56327 Then 'If it is not an Embedded or linked object oldFileName = System.IO.Path.GetFileNameWithoutExtension(oFileDesc.FullFileName) 'Collect old file information oldFileExt = System.IO.Path.GetExtension(oFileDesc.FullFileName) oldFilePath = System.IO.Path.GetDirectoryName(oFileDesc.FullFileName) oldFileRelPath = Mid(oldFilePath,cLocs.mLocLen,1000) & "\" 'MsgBox(oldFileRelPath) 'projFlowNum = Parameter("projectNum") & Parameter("flowNum") & Parameter("projectSEQ") & "\" projFlowNum = Parameter("projectNum") & Parameter("flowNum") oldFileNameExt = oldFileName & oldFileExt 'newFilePath = cLocs.newLoc & oldFileRelPath newFilePath = cLocs.newLoc & "\" 'If Not oldFilePath.Contains("STANDARD PARTS") Then 'Uncomment this and the EndIf to keep the STANDARD PARTS folder parts from being renamed If oldFileName.Contains("XXXXXXXX-XX") Then newFileName = oldFileName.Replace("XXXXXXXX-XX", projFlowNum & "-" & oProjSEQ) & oldFileExt Else If oldFileName.Contains("XXXXXXXX") Then newFileName = oldFileName.Replace("XXXXXXXX", projFlowNum) & oldFileExt Else newFileName = oldFileName & "_" & Parameter("projectNum") & Parameter("flowNum") & oldFileExt 'Create new file name End If 'MsgBox(oldFileName & " - " & oldFileExt & " - " & oldFilePath & " - " & newFileName & " - " & newFilePath) 'End If 'MsgBox(newFilePath) ' If newFilePath.Contains("XXXXXXXX-XX") Then ' newFilePath = newFilePath.Replace("XXXXXXXX-XX", (projFlowNum & "-" & oProjSEQ)) ' End If ' If newFilePath.Contains("XXXX-FILTER") Then ' newFilePath = newFilePath.Replace("XXXX-FILTER", projNum & "-FILTER") ' End If If Not System.IO.Directory.Exists(newFilePath) 'MsgBox("Creating: " & newFilePath) System.IO.Directory.CreateDirectory(newFilePath) End If If Not System.IO.File.Exists(newFilePath & newFileName) Then 'If the file doesn't exist 'MsgBox(oFileDesc.FullFileName & " - " & newFilePath & newFileName) Try Call ThisApplication.FileManager.CopyFile(oFileDesc.FullFileName, newFilePath & newFileName) 'Copy the file to the new location Catch MsgBox("ERROR COPYING: " & oFileDesc.FullFileName & " - " & newFilePath & newFileName) End Try Dim fInfo As FileInfo = New FileInfo(newFilePath & newFileName) If fInfo.IsReadOnly = True Then fInfo.IsReadOnly = False End If End If Try 'MsgBox("File Desc: " & oFileDesc.FullFileName & vbCrLf & vbCrLf & "New Folder: " & newFilePath & vbCrLf & vbCrLf & "New File Name: " & newFileName & vbCrLf & vbCrLf & "Master Path: " & cLocs.masterLoc & vbCrLf & vbCrLf & "New Path: " & cLocs.newLoc & vbCrLf & vbCrLf & "Relative Path: " & oldFileRelPath )'& "oFileDesc DisplayName: " & availDoc.DisplayName) oFileDesc.ReplaceReference(newFilePath & newFileName) 'Replace the file reference with new copy Catch MsgBox("Error Replacing: " & newFilePath & newFileName & vbCrLf & System.IO.File.Exists(newFilePath & newFileName)) End Try availDoc = oFileDesc.ReferencedFile.AvailableDocuments.Item(1) iProperties.Value(newFileName, "Custom", "OldName") = oldFileNameExt '************ Replaces the iProperty "Part Number" with the project and flow number ************** Dim projectNumberString As String Dim iPN As String Dim iPNa As String iPN = iProperties.Value(newFileName, "Project", "Part Number") projectNumberString = projectNum & flowNum & "-" & projectSEQ projectNumberString2 = projectNum & flowNum b = iPN.Contains("XXXXXXXX-XX") If b Then iPN = iPN.Replace("XXXXXXXX-XX",(projectNumberString)) iProperties.Value(newFileName, "Project", "Part Number") = iPN 'MsgBox("iPN = " & iPN & " AND the file name is " & newFileName & " And the part number iProperty contains the X's: " & b) availDoc.Save Else If b Then iPN = iPN.Replace("XXXXXXXX",(projectNumberString2)) iProperties.Value(newFileName, "Project", "Part Number") = iPN availDoc.Save End If 'If the document is a subassembly, run this whole function again on the subassembly If oFileDesc.ReferencedFileType = 56323 Then subDoc = oFileDesc.ReferencedFile.AvailableDocuments.Item(1) Call CopyFiles(subDoc) End If End If Next 'iLogicVb.RunRule("UPDATE") End Sub '[====List of FileTypeEnums===== 'kAssemblyFileType 56323 An Assembly file. 'kDesignElementFileType 56326 A design element file. 'kDrawingFileType 56324 A drawing file. 'kForeignFileType 56327 A foreign file. 'kPartFileType 56322 A part file. 'kPresentationFileType 56325 A presentation file. 'kUnknownFileType 56321 An unknown type Of file.
