Convert - [Tool] Convert Polyline to Spline (2D) - from VBA to VB.Net
GeorgK
GeorgK
Hello together,
I try to convert this tool:
https://forums.autodesk.com/t5/inventor-forum/tool-convert-polyline-to-spline-2d/m-p/8779347?collaps...
But I have an error in my code:
Private Sub PreviewPoints()
        ' Generierung der Liste der aktuellen Punkte  ' Erstellen der Punkte und Hinzufügen zur Punkteliste
        Dim oSelectSet As SelectSet
        oSelectSet = m_inventorApplication.ActiveDocument.SelectSet
        oSelectSet.Clear()
        Dim oTransGeom As TransientGeometry
        Dim nPointPreview As Object
        'Dim nPoint As Object = Nothing
        oTransGeom = m_inventorApplication.TransientGeometry
        Dim oPreviewPoints As ObjectCollection
        oPreviewPoints = m_inventorApplication.TransientObjects.CreateObjectCollection
        Dim oPoints(nPoint) As Point2d
        For i = 1 To nPoint
            ' Generieren des aktuellen Punkts
            oPoints(i) = oTransGeom.CreatePoint2d(oPointCoordX(i), oPointCoordY(i)) '==>>> Error
            ' Aufnahme des Punkts in die Liste
            oPreviewPoints.Add(oPoints(i))
        Next i
        'oSelect.Select oPreviewPoints
        ' Hinzufügen der Punkte zur aktuellen Ebene
        Dim oSketch As PlanarSketch
        oSketch = m_inventorApplication.ActiveEditObject
        For i = 1 To nPoint
            ' Generieren des aktuellen Punkts als Mittelpunkt (mit Markierung)
            oSketch.SketchPoints.Add(oPoints(i), True)
        Next i
        ' Warten auf die Bestätigung
        MsgBox("Vorschau beenden")
        ' Löschen der aktuellen Punkte
        nPointPreview = oSketch.SketchPoints.Count
        For i = nPointPreview To nPointPreview - nPoint + 1 Step -1
            '  MsgBox "Typ: " & TypeName(obj)
            ' Selektieren des aktuellen Punkts
            oSelectSet.Select(oSketch.SketchPoints(i))
        Next
        oSelectSet.Delete()
    End Sub
Thank you
Georg
Replies (16)
Frederick_Law
There is a lot more then just convert to VB.Net.
You can find a template from SDK.
Take a look at API help on addin development.
GeorgK
Hello @Frederick_Law ,
I have an add-in already. This tool would be nice to have it in my add-in 🙂
Georg
Frederick_Law
I think you have VBA macro?
And try to convert it to an "app" or addin?
I read you other post.
GeorgK
In the other post is a VBA macro.
https://forums.autodesk.com/autodesk/attachments/autodesk/78/744546/4/DialogPolylineToSpline.zip
I tried to convert it to VB.Net for my existing add-in.
Attached is a standalone version.
chandra.shekar.g
Autodesk Support
Autodesk Support
@GeorgK,
Can you please explain the requirement in detail with non confidential VBA code?
what is nPoint variable (Declared, but not defined properly)?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
GeorgK
Hello @chandra.shekar.g ,
I tried to convert the VBA program from my initial post to VB.Net.
Thank you
Georg
weiser
Hi there,
I'm the author of the VBA-Tool. I've put the whole code into a VBA-UserForm. And to keep it simple I am using some "global" declarations in the beginning of the code.
So the prefix 'n' is for number of, 'm' for maximum number of, 'o' for object, 'i' for indices. Maybe this helps reading the code, because I did all the comments in German 😉
Regards
chandra.shekar.g
Autodesk Support
Autodesk Support
@GeorgK,
Can you please provide reproducible steps to investigate?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
GeorgK
I tried to convert it to VB.Net. There is an error in the marked line:
        oSelectSet.Clear()
        For i = 1 To nPoint
            oPoints(i) = oTransGeom.CreatePoint2d(oPointCoordX(i), oPointCoordY(i)) '==>>> Error !!!!
        Next i
        For i = 1 To nPoint
        Next i
        Next
        oSelectSet.Delete()
    End Sub
chandra.shekar.g
Autodesk Support
Autodesk Support
@GeorgK,
DialogPolylineToSpline.zip contains DialogPolylineToSpline.frm and DialogPolylineToSpline.frx files which may not used to debug the code. Can you please provide non confidential solution to debug the code?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
GeorgK
attached is the coverted file.
Thank you
Georg
chandra.shekar.g
Autodesk Support
Autodesk Support
@GeorgK,
Can you please provide non confidential sample model data and steps to reproduce the issue?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
GeorgK
Hello @chandra.shekar.g,
attached is a sample model.
Thank you
Georg
chandra.shekar.g
Autodesk Support
Autodesk Support
@GeorgK,
Gave a try to reproduce the error. But inventor crashed in between while testing it. Can you please give reproducible steps to test the behavior?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
GeorgK
the ipt is working with the VBA code.  But it's not working with the VB.Net code. I couldn't find the answer for the crash.
Thank you Georg
chandra.shekar.g
Autodesk Support
Autodesk Support
@GeorgK,
Hoping that below change may be helpful.
        oSelectSet.Clear()
        For i = 0 To nPoint -1
        Next i
        For i = 1 To nPoint
        Next i
        Next
        oSelectSet.Delete()
    End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
