Hi @coffeeoffshore
I would recommend follow the same procedure of how you would do this manually. I think this would be just a angle constraint to keep the witlre parralel to your desired angle. Or else a mate constraint depending on how your part is set up. Any ilogic influence will be just the automation of manual methods.
If this solved a problem, please click (accept) as solution.
Or if this helped you, please, click (like)
Regards
Alan
