Compile Error: Object Required - Inventor API
Mark.Lancaster
Consultant Consultant
Mark.Lancaster
After about 3 to 4 years of not programming, I'm getting back into it and using the Inventor API, so yes a newbie..  😁
Ran into an issue and trying to figure out why I'm getting a Compile Error.   This program is nothing big and just want a message box to show the radius of all the fillet features in my part file.
Private Sub Codeme()
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.ActiveDocument
Dim oFilletFeatures As FilletFeatures
Set oFilletFeatures = oPartDoc.ComponentDefinition.Features.FilletFeatures
Dim Counter As Integer
For Counter = 1 To oFilletFeatures.Count
    Dim oFillet As FilletFeature
    Set oFillet = oFilletFeatures.Item(Counter)
    Dim oFS As ModelParameter
    Set oFS = oFillet.FeatureDimensions.Item(1)
    Dim oFS1 As Double
    Set oFS1 = oFS.Parameter.ModelValue
    MsgBox (oFS.Parameter.ModelValue)
Next
Why in the world is the line of Set oFS1 = giving me this error?    When ModelValue type is "double".   But I can take the oFS.Parameter.ModelValue statement and use it directly with the MsgBox line and I see the fillet information I need...
Working in 2020 if that makes a difference...
Update:  Yes there's probably others ways this entire program can be coded..   I'm not looking for a redo of the entire program.  Just an answer in why this given line is throwing a fit.  Thanks...
Mark Lancaster
HideoYamada
Hello Mark,
"Set" is not need for double. "Set" is used for objects.
I can't explain why sometimes needed , or not needed. Because it's difficult to say with my poor English ability.
But you will find the answer by using google.
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
Mark.Lancaster
@HideoYamada
Thanks for the reply and answer..  I thought that earlier but when i changed it I saw another error .   So I was confused.   But I just realized the new error was associated to another portion of the code.   In the end..  2 rookie mistakes..  😃.
Mark Lancaster
