Hi, I'm new to inventor customization , Help in finding the solution for this!!
I have an assembly, i need to get the details(Name, value, type) of user parameters from the individual parts in assembly and export it to csv file.
which all functions do i need to use and how get the parts from assembly?
Hello @Anonymous
You could start with a VBA macro like this:
Public Sub GetUserParameters() If ThisApplication.ActiveDocumentType <> kAssemblyDocumentObject Then Exit Sub Dim myAssy As Inventor.AssemblyDocument Set myAssy = ThisApplication.ActiveDocument Dim myDoc As Inventor.Document For Each myDoc In myAssy.AllReferencedDocuments If myDoc.DocumentType = kPartDocumentObject Then Dim myPart As Inventor.PartDocument Set myPart = myDoc Dim myUP As Inventor.UserParameter For Each myUP In myPart.ComponentDefinition.Parameters.UserParameters Debug.Print "User Parameter " & myUP.Name & " is type " & TypeName(myUP.Value) & " with value " & CStr(myUP.Value) Next myUP End If Next myDoc End Sub
It just dumps to the VBA immediate view all userparameters in all parts in the active assembly.
Jens Bejer Pedersen
Developer, Symetri A/S
