Code stopped working 2014 upgrade 2021
5 REPLIES 5
Jef_E
380 Views, 5 Replies
Hi all,
We are currently going to migrate to 2021, and I am checking some 'custom' work we have running. Sadly I cannot seem to get it to work to the full extent. Previously I did a check to the 2019 version and did not encounter the same problem
I receive following error when editing a parameter  value.
The current value = 30
The new value = 35
I can't seem to figure it out why this is failing.
Kind regards,
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
5 REPLIES 5
Jef_E
in reply to: Jef_E
In addition I did another test; I started a new plugin using the guide, with following code, producing the same error when setting the value.
    Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
        Dim oDoc As PartDocument = _invApp.ActiveDocument
        Dim oParameter As Parameter = oDoc.ComponentDefinition.Parameters.Item("Nozzle_length_positioning")
        MsgBox(oParameter.Value)
        oParameter.Value = 35
    End Sub
Kind regards,
Inventor 2014 SP2
raith-mb
in reply to: Jef_E
Did you try
...Value = (Value / 10)
Regards Roland
Jef_E
in reply to: raith-mb
@raith-mb wrote:
Did you try
Regards Roland
No I did not, as this is not the problem...
Inventor 2014 SP2
JhoelForshav
in reply to: Jef_E
Hi @Jef_E
I've tried to reproduce the error in both inventor 2020 and 2021 with no luck... which Autodesk.Inventor.Interop.dll are you referencing? Could you attach a simple VS project where this error occurs?
DRoam
in reply to: Jef_E
On the line that fails, if you hover over the three highlighted terms below, what does Visual Studio say is their type (e.g. hovering over "Value" shows "Property Parameter.Value As Object")?
oParameters Item("Nozzle_length_positioning") . Value = value / 10
