Hi, I have a question for the experts.
About using the ilogic to automatically check the file name.
Check whether the file name of the drawings are consistent with the iProperty name of part.
See the figure below for details
To further explain, because we have a lot of drawings and expect each drawing to be automatically checked.
I expect that this is what you are looking for:
Dim doc As DrawingDocument = ThisDoc.Document
Dim sheet As Sheet = doc.Sheets.Item(1)
Dim firstView As DrawingView = sheet.DrawingViews.Item(1)
Dim refDoc As PartDocument = firstView.ReferencedDocumentDescriptor.ReferencedDocument
Dim docFileName = System.IO.Path.GetFileNameWithoutExtension(doc.FullFileName)
Dim refDocFileName = System.IO.Path.GetFileNameWithoutExtension(refDoc.FullFileName)
If (docFileName <> refDocFileName) Then
MsgBox(String.Format("Drawing filename {0} is not the same as {1}", docFileName, refDocFileName))
Jelte de Jong
Blog: hjalte.nl - github.com
Jelte de Jong
Thank you for your reply. I'll test this ilogic rule.
