Check Part into Vault Using VBA
eric.frissell26WKQ
eric.frissell26WKQ
Hi, I was wondering if anyone knows whether or not it's possible to run a VBA macro from the Inventor environment that checks a part into the vault and, if so, what is the or where can I find the syntax for that?
A.Acheson
Not a lot of info relating to VBA but here is an iLogic code to check in using the command button.
https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/vault-check-in-through-ilogic/td-p/9811...
There is a few ilogic post floating around that uses keyboard strokes to fill in check information as well.
Regards
Alan
eric.frissell26WKQ
Thanks Alan!
