Changing projects; VBA vs. manual
mr_ensing
Message 1 of 20
mr_ensing
Summary: I find that changing the project (*.ipj) within a VBA macro results in errors that don't occur when i change manually (by way of the Project manager).
The situation:
  • For every client project there is a unique Inventor project file;
  • A collection of 'standards', assy with drawing, to be copied to a project and modified there;
  • Inventor (and Vault Basic) 2015.
I have a elaborate 'copy design' macro (in VBA). The macro:
  • copies a drawing or assembly (including referenced document) from one project to another;
    renames all the files according to new project and subject;
  • edits iproperties of files according new project and subject;
  • replaces ReferencedFileDescriptors to new filenames and paths;
  • all the copying and replacing is done within a single-user project-file that excists for this purpuse.
Global workflow:
  1. So the user starts within a project and target design loaded,
  2. User starts the 'copy design' macro,
  3. User is asked to input target project and subject,
  4. Macro activates a single-user project-file (copy_object.ipj),
  5. Copying and replacing of references takes place,
  6. Macro unloads everyting, activates target project-file and opens result.
Two problems arise, both of wich i attribute to the changing of project files in VBA:
  1. The replacing of ReferencedFileDescriptors goes haywire.
    • This only happens if i leave the activating of the copy_object.ipj to the VBA macro itself.
    • When the user changes to copy_object.ipj before using the macro, not a single problem with the ReferencedFileDescriptors.
  2. At the end when the target project-file is activated and the result is opened, it is not possible to check the design in the Vault. Solution is to manually change to a random different project and back.
My conclusion is, that activating a project by way of VBA code gets me in some sort of project twilight zone.
My question, how to fix this?
I tried to isolate and clean up all the project-related code into a sub routine. No difference. Code:
Sub ChangeProj(aProj As String)
If ThisApplication.Documents.Count > 0 Then
    ThisApplication.Documents.CloseAll
Dim aDesignProjectMgr As DesignProjectManager
Dim aProjectNew As DesignProject
Set aDesignProjectMgr = ThisApplication.DesignProjectManager
On Error Resume Next
Set aProjectNew = aDesignProjectMgr.DesignProjects.ItemByName(aProj)
If Err.Number <> 0 Then
    aDesignProjectMgr.DesignProjects.AddExisting (aProj)
Err.Clear
On Error GoTo 0
aProjectNew.Activate
End Sub
Manual changing of projects like this:
Replies (19)
Message 2 of 20
rossano_praderi
I've tried your code and for my testing I made some clean.
I've also added two lines of code that showing up the registered project names, in this way you can see the right name to use within your macro
Sub project()
    ChangeProj ("Inventor2016")
End Sub
ThisApplication.DesignProjectManager.DesignProjects.ItemByName(aProj).Activate
End Sub
Sub Prjlist()
For Each adis In ThisApplication.DesignProjectManager.DesignProjects
    Debug.Print adis.Name
Next
End Sub
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
Message 3 of 20
mr_ensing
I like how you cleaned up the code. I tried to get my code as minimal as possible. I do however need the AddExisting line for some situations, but for testing it does not matter.
Your Sub Prjlist() addition made me think about what string to input into this sub. I was parsing in the full path and filename ("C:/***/***/project.ipj").
So i tried to parse only the project name (basically the filename, without path and extension). This also works fine, but does not solve my problems.
For now i can only conclude that the VBA way of changing projects differs from the 'manual' way.
Thanks.
My current code:
On Error Resume Next 'optional code
If Err.Number <> 0 Then 'optional code
ThisApplication.DesignProjectManager.DesignProjects.AddExisting (aProj) 'optional code
ThisApplication.DesignProjectManager.DesignProjects.ItemByName(aProj).Activate 'optional code
Err.Clear 'optional code
End If 'optional code
On Error GoTo 0 'optional code
End Sub
Message 4 of 20
mr_ensing
With further testing i isolated the second problem i have to a single line of code.
  1. ...
Method 1:
  1. Start in project A,
  2. Use project dialog to ('manually') activate project B,
  3. Open a drawing, assy or part and try to check it in the Vault.
Method 2:
  2. Use test code to activate project B,
The line of code:
Public Sub test()
ThisApplication.DesignProjectManager.DesignProjects.ItemByName("I:\...\Project_B.ipj").Activate
End Sub
Method 1 just works.
With method 2 i get the following error:
If i click the Map Folders button end up in the project Twiligth Zone:
Message 5 of 20
rossano_praderi
Hi Ensing,
I'm sorry for the late response, I been quitely busy in these days.
My last post was only for testing part of the final code.
Now the following code activate or create and activate a new project starting from an existing project template, that is locally.
Sub ChangeProj(ByVal aProj As String, ByVal pSource As String) 'work only with vault projects
Dim dProMan As DesignProjectManager
'Dim mProj As DesignProject ' optional code
Dim wPath As String ' workarea path
Set dProMan = ThisApplication.DesignProjectManager
wPath = Left(dProMan.ActiveDesignProject.WorkspacePath, _
        InStrRev(dProMan.ActiveDesignProject.WorkspacePath, "\"))
If Dir(dProMan.DesignProjects.ItemByName(aProj).FullFileName) = "" Then
    'FileCopy pSource, wPath & aProj & ".ipj" ' all projects within the same folder (workarea)
    MkDir (wPath & aProj) ' make project folder, not needed if you use the workarea for all projects
    FileCopy pSource, wPath & aProj & "\" & aProj & ".ipj" ' each project with its folder
    dProMan.DesignProjects.AddExisting(wPath & aProj & "\" & aProj & ".ipj").Name = aProj
    dProMan.DesignProjects.ItemByName(aProj).VaultVirtualPath = _
        Replace(dProMan.DesignProjects.ItemByName(aProj).VaultVirtualPath, "Design", aProj)
' you can use the follow code if you need to check or adjust some project informations
'    Set mProj = dProMan.DesignProjects.ItemByName(aProj)
'    With mProj
'        .WorkspacePath = Replace(.WorkspacePath, "pSource", aProj) ' as an example
'    End With
    dProMan.DesignProjects.ItemByName(aProj).Activate
Else
End Sub
This simple routine printout some project informations
Sub mProject(ByVal pName As String)
    Dim mP As DesignProject
    Set mP = ThisApplication.DesignProjectManager.DesignProjects.ItemByName(pName)
    With mP
        Debug.Print "WorkspacePath " & .WorkspacePath
        Debug.Print "ContentCenterPath " & .ContentCenterPath
        Debug.Print "DesignDataPath " & .DesignDataPath
        Debug.Print "FullFileName " & .FullFileName
        'Debug.Print .VaultVirtualPath
        'Debug.Print .ProjectType
        'Debug.Print .TemplatesPath
        'Debug.Print .VaultServer
    End With
End Sub
 With this macro you have to map the root project folder within the Vault.
As I know, if you use vba you can't access to some Vault API, because these are not COM shared.
The follow link explain it better (https://forums.autodesk.com/t5/inventor-customization/vault-access-through-inventor/td-p/5560858)
I'm reading in your post footprint that you are using VS2010, I don't think you did need more explanations on how to proceed.
I know this post doesn't solve your problem, but I believe that can be usefull.
Bregs
Rossano Praderi
Message 6 of 20
mr_ensing
I'll won't be at work before monday, so i can't really test anyting until then. But i think i have to clarify my latest comment: I'm not trying to check in a design by way of VBA. I do however have trouble checking in anything after switching between projects by way of VBA.
Method 1:
  1. User starts in project A,
  2. User uses the project dialog to ('manually') activate project B,
  3. User opens a drawing, assy or part (within project B) and tries to check it in the Vault.
Method 2:
  2. User applies VBA test code to activate project B,
Test code:
Sub test()
End Sub
Method 1 is fine. Method 2 results in the project twilight zone i mentioned before. But I can't find any other way to activate a project (in VBA) than this method.
That being said, thanks for your comment. I'm sure i'm going to be using parts of your code to improve other aspects of my macro.
Thanks.
Message 7 of 20
mr_ensing
The VS2010 is in my signature because i have it at my disposal. It's used for a addin we run. I'm trying to avoid converting this macro to a VB.NET addin, due to time constraints. But i might try a addin with only the aformentioned test code, to see if this specific issue on solved in VB.NET.
Message 8 of 20
mr_ensing
Update:
It looks like i fixed the errors with the replacing of ReferencedFileDescriptors. It was a simple fix.
'I replaced this line:
if stringA = stringB then 'do stuff
'with this line:
if StrComp(stringA, stringB, vbTextCompare) = 0 then 'do stuff
The weird thing is that the problem only occurred in some project-related situations. StringA and StringB would be 100% equal, but the code was not seeing it. The StrComp-function fixes that.
Message 9 of 20
rossano_praderi
Well done!
I'm a little bit confuse, did you posted that part of your code?
I haven't seen it.
Anyway I'm happy to see that you solved this issue by yourself.
Bregs
Rossano Praderi
Message 10 of 20
mr_ensing
No, that part i did not post before. I mentioned it in the original post:
Problem 2 was easier to isolate, so i focused on that. That issue is still very much alive by the way.
Some more info on problem 1, wich i just fixed:
The macro copies a bunch of files to a new path and new filenames. After that the ReferencedFileDescriptors within all these files have to be fixed. That happens in a sub. This sub cycles through the ReferencedFileDescriptors of a file and compares the existing ReferencedFileDescriptors with an old filename. When those are equal, the reference is changed to the new filename.
Somehow this did not work properly when the copy_object project was activated by the macro. Of course, when this (changing project) is done by the user (manually) then there was no problem.
The new method does not care. So that's great. But i still don't understand.
Message 11 of 20
sundaram1087
Hi
             Am facing the same issue while changing the inventor Project file by vb.net . Have you get any solution on that? Could you please share the solution for that if any
Regards
K.Shunmuga sundaram
Message 12 of 20
mr_ensing
No solution from me. I'm still in VBA. Upgraded to IV2018 (from 2015). It's less of a problem now, but it is still there.
I was thinking to rewrite the entire macro and maybe move to VB.NET. I was kind of hoping that VB.NET would fix this problem. I guess not...
Message 13 of 20
sundaram1087
Hi
          Thanks for your reply.
Regards
K.Shunmugasundaram
Message 14 of 20
bulrich-finn
I have the same issue when I change the project via the COM interface. I can locate the project I want within DesignProjectManager.DesignProjects. I can change the project by calling .Activate on that object. And I can see that the active project apparently changes, both in the Inventor UI and by checking DesignProjectManager.ActiveDesignProject.Name.
However, when I go to open files using Apprentice, it pulls references from the wrong location. If I manually change the project in the Inventor UI, then Apprentice behaves nicely.
Message 15 of 20
mr_ensing
I barely remember this post. But i still have some code changing projects. I'll post my current code.
Function ChangeProj(ByVal targetProjectPath As String) As Boolean
    'returns True if succesfull
    Dim CurrentProject As String
    CurrentProject = ThisApplication.DesignProjectManager.ActiveDesignProject.fullfilename
    If StrComp(CurrentProject, targetProjectPath, vbTextCompare) = 0 Then
        ChangeProj = True
        Exit Function
    Else
        ChangeProj = False
    If ThisApplication.Documents.count > 0 Then
    If Not FileExists(targetProjectPath) Then
        Exit Function
    ThisApplication.DesignProjectManager.DesignProjects.ItemByName(targetProjectPath).Activate
        ThisApplication.DesignProjectManager.DesignProjects.AddExisting (targetProjectPath)
        Err.Clear
    On Error GoTo 0
    ChangeProj = True
End Function
Message 16 of 20
bulrich-finn
And this code works? Interesting. I'm wondering if this got fixed in a later version of Inventor. We're still currently running 2022.
Thanks for sending the code!
Message 17 of 20
mr_ensing
I re-wrote the entire macro a few years ago. Still in VBA. Works without problems for years by now. Can't remember when or what solved my problems.
You're mentioning changing projects in Inventor. But your problem is with Apprentice?
Message 18 of 20
bulrich-finn
Yes, from what I understand Apprentice follows the active project of Inventor with no way to change that via Apprentice controls.
Message 19 of 20
mr_ensing
I got curious.
I seems you're right. And maybe also wrong.
I tested running Apprentice from Excel VBA. It got the wrong project file. And, in my case, some files from the wrong library location.
So i tested some more. I got it to find the right project file and activate it:
Dim invApprentice As New ApprenticeServerComponent
Debug.Print invApprentice.DesignProjectManager.ActiveDesignProject.Name
Dim aProject As DesignProject
For Each aProject In invApprentice.DesignProjectManager.DesignProjects
	If StrComp(aProject.Name, cProject.Full, vbTextCompare) = 0 Then
		Call aProject.Activate
		Exit For
Next aProject
'if not found
	'Set aProject = invApprentice.DesignProjectManager.DesignProjects.AddExisting("filename")
	'Call aProject.Activate
'end if
Message 20 of 20
bulrich-finn
Oh, that's great! I had read somewhere that Apprentice doesn't support changing projects, but that's clearly not true. It does apparently pick on on project changes in Inventor, but not consistently. (I think it may have to do with if an instance of Apprentice is already running or not, but I haven't tested to be sure.)
Either way, I was able to use your code as an example and my application is now up and running consistently! Thank you for taking the time to help me out!
