Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Change text style font for all text styles
1 REPLY 1
dialunau
166 Views, 1 Reply
I'm trying to change all text style font in a drawing document, regardless of the style they belong to. The problem is I'm getting an error while overwriting some text styles (it works for some styles, then I get the error below). Can someone help with this? I would really appreciate it.
Here is the code I'm using:
Dim oDDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oTM As TransactionManager = ThisApplication.TransactionManager
Dim oTS As TextStylesEnumerator = oDDoc.StylesManager.TextStyles
Dim sNameTextB As String = "MyTxtStyle"
Dim oStyleB As TextStyle = oTS.Item(sNameTextB)
Dim newTM As Transaction = oTM.StartTransaction(oDDoc, "ChangeTextStyle")
For Each oStyleA As TextStyle In oDDoc.StylesManager.TextStyles
	If oStyleA.Font <> oStyleB.Font Then
		oStyleA.Font = oStyleB.Font
	End If
Next oStyleA
newTM.End()
1 REPLY 1
dialunau
in reply to: dialunau
It turns out that running the code would try to change all style, including the not in use text styles included in the global styles, so I just had to tweak the code to work only on the in use text styles and now it works just fine.
Technology Administrators
