change raster view to exact view
GeorgK
Advisor Advisor
GeorgK
Hello together,
how could I change the view mode from raster to exact view for all sheets and views? Does the API support it?
Thank you Georg
rjay75
Here's some iLogic code to cycle through all the sheets and views of a drawing and unset the raster view.
For Each sheet As Sheet In ThisDrawing.Document.Sheets
    If sheet.DrawingViews.Count > 0 Then
        For Each view As DrawingView In sheet.DrawingViews
            view.IsRasterView = False
        Next
Next
GeorgK
Hello Rodney,
thank you.
Georg
RValdesDIM
For some reason I have multiple views having Raster view activated even though it is not checked.  This produces many problems and the only fix I have found is editing each view checking the Raster view box then clicking OK; ONLY to have to go back into the edit view and uncheck Raster view then click OK does it finally reset to exact view.
I see the code discussed here and wondered what the code is to turn on Raster view for all views in the file and then I can follow with the turn off all.
Any help would be greatly appreciated!!
DavidWarta
Currently I have the same problem. Saving the drawing, close inventor and reopen the drawing seemed to have done the trick for me this time.
D. Warta
Van Halteren Technologies B.V.
D.Warta
Van Halteren Technologies Boxtel B.V., Netherlands
