Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
change picture of buttondefinition
11 REPLIES 11
Message 1 of 12
473 Views, 11 Replies
I want to change the picture of a buttondefinition.
How can I do that?
Geert
Code:
'Make Button
Dim objControlDefs As ControlDefinitions
Set objControlDefs = objInventorApp.CommandManager.ControlDefinitions
Dim objUpdateModelCmdPicture As IPictureDisp
Set objUpdateModelCmdPicture = LoadResPicture(126, vbResIcon)
Set mobjUpdateModelCmd = objControlDefs.AddButtonDefinition("Update Model", "UpdateModelCmd", kQueryOnlyCmdType, strClientID, , , objUpdateModelCmdPicture, objUpdateModelCmdPicture)
'Change picture of button
Set objUpdateModelCmdPicture = LoadResPicture(127, vbResIcon)
Dim objCommandBars As CommandBars
Set objCommandBars = objUserInterfaceMgr.CommandBars
'select commandbar where button resides
Dim objDataLINKCmdBar As CommandBar
Set objDataLINKCmdBar = objCommandBars.Add("DataLINK", "DataLINKCmdBar", kRegularCommandBar, strClientID)
'?????? How to change the picture of commandbutton
objDataLINKCmdBar.Controls.Item ("UpdateModelCmd")
How can I do that?
Geert
Code:
'Make Button
11 REPLIES 11
Message 2 of 12
It is not possible to change the image of a button once it has been created.
Sorry.
Sanjay-
Sorry.
Sanjay-
Message 3 of 12
OK, then I must do this by enable.
Not so nice but it works.
Geert
Geert
Message 4 of 12
"I must do this by enable."
Can you explain that part?
We need to put one icon in green color when is running and it must change to red when is not connected.
Message 5 of 12
It would be easiest if you created 2 ButtonDefinitions (1 green and 1 red)
and placed the appropriate button as needed.
Sanjay-
Sanjay-
Message 6 of 12
Thanks Sanjay, Ok, I try to do it as you say
Message 7 of 12
There are 2 options.
1) define 2 buttons such as Sanjay said
2) define one button and enable it or not.
In our case the green button says model is OK, the red button says model needs care and clicking on it run a program. The green button is (for us) then useless because it don't have to do anything, so now we have one button (red) which is enabled when the model needs care and is not enabled when the model is OK.
This is the same behavior as Inventor does. (see Update button)
Geert.
Used Code:
Private Sub mobjApplicationEvents_OnNewView(ByVal ViewObject As Inventor.View, ByVal BeforeOrAfter As Inventor.EventTimingEnum, ByVal Context As Inventor.NameValueMap, HandlingCode As Inventor.HandlingCodeEnum)
Dim objControlDefs As Inventor.ControlDefinitions
objControlDefs.Item("UpdateModelCmd").Enabled = True
End sub
Geert.
Used Code:
End sub
Message 8 of 12
Ok many thanks to both
Pretty explications Geert.
Our case is similar as you described, but is different in one point, when the macro is running de button must be in (green) disabled mode and (red) enable in case the macro is not running or fails.
Sorry my english is not good and I'm not a VBA experienced programmer.
It´s possible that one macro knows if another macro is running?
Message 9 of 12
I don't know exactly what you mean.
When starts your macro up? Automatically in a event such as mine? If so you can make your macro as a function which gives a boolean back as result. Something like this:
Private Function CheckMacroRuns (....) as boolean
if Macroruns then
CheckMacroRuns = True
else
CheckMacroRuns = False
end Function
'Controlling buttons
if CheckMacroRuns = true then
objControlDefs.Item("GreenCmd").Enabled = True
objControlDefs.Item("RedCmd").Enabled = False
Else
objControlDefs.Item("GreenCmd").Enabled = False
objControlDefs.Item("RedCmd").Enabled = True
end if
if Macroruns then
else
end Function
Else
end if
Message 10 of 12
Thanks again it's very clear what you said.
And yes, my macro starts automatically.
Then it cloud be something like this:
'In Module
Option Explicit
Public oEvent As clsEvent
Private Function AutoStart() as boolean
Set oEvent = New clsEvent
oEvent.Initialize
if AutoStart then
AutoStart=true
else
AutoStart=false
end if
End Function
'and in class modules
Option Explicit
Private WithEvents oModelingEvents As ModelingEvents
Private WithEvents oApplicationEvents As ApplicationEvents
Private WithEvents UserInputEvents As UserInputEvents
Private Sub Initialize()
Set oModelingEvents = ThisApplication.ModelingEvents
Set oApplicationEvents = ThisApplication.ApplicationEvents
Set UserInputEvents = _
ThisApplication.CommandManager.UserInputEvents
End Sub
'In Module
Option Explicit
oEvent.Initialize
if AutoStart then
AutoStart=true
else
AutoStart=false
end if
End Function
Option Explicit
End Sub
Message 11 of 12
Will this be possible in the future?
Ronny
Re: change picture of buttondefinition
Sorry.
Sanjay-
Ronny
Sorry.
Sanjay-
Message 12 of 12
No plans for this yet.
Sanjay-
Sanjay-
