- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I could use some help with changing the material of certain parts in my assembly using iLogic.
I've seen various threads that can change all parts within an assembly, but I need to change parts using a specific Display Name. I need to use the Display Name because the file names can change when the assembly is copied using Vault's Copy Design.
I have a multi-value parameter at the assembly level, and when the user selects a new value, I need to change the corresponding component's material.
The materials are all local at the part level so I think this will simplify the coding.
