change from the Ilogic programming the date format
Miguel.CarvajalS34Q6
the output format of the date is required to be different.
but it cannot be adjusted from windows, it is necessary to change it from inventor using Ilogic.
from windows the format is MONTH/DAY/YEAR, and you want to leave it YEAR/MONTH/DAY
Accepted solutions (3)
A.Acheson
You could use some ilogic to change the format see post1
And here is the format in windows help for formatting  dates.
An example
DateTime.Now.ToString("yyyyMMdd”)
Regards
Alan
thanks, but the code does not work, it must be some restiction that windows has
A.Acheson
It works for me to create a string. Can you show how you implemented it's use?
Regards
Alan
In a few words, what I need is to change the format of the date, whether it is a property of the project, of the status or custom, change the output format of the dates.
A.Acheson
So by your latest request to have existing date string that maybe not the DateNow the task gets more difficult. You will need to research and use a function to read the incoming date string, determine the culture/region it belongs too and then convert to your preferred format. This is a difficult task as I found in my testing. If you want to marked this post as not solved you might get more experienced eyes on the problem your facing. Here is a post that shows how to convert a string to date, I hope it is helpful.
Regards
Alan
