iLogic to create custom iproperty for current date with Hr min no seperators
jonathan
jonathan
Hello Forum,
We are looking for help to create an iLogic rule that will be run manually.  This rule would create(if missing) a custom iproperty for current date(year/month/day) with hours and minutes directly after with no seperators.
example: 2016-12-16 18:48  would create an iproperty: 201612161848
In the end we are wanting to use this iproperty on the end of a part number on an inventor drawing that will be added manually.
Any help would be much appreciated
Thank you
Curtis_Waguespack
Hi sharpj,
Here's an ilogic snippet that does what you're after.
I hope this helps.
Curtis
Dim Time As DateTime = DateTime.Now
Dim Format As String = "yyyyMdHHmm"
Dim oPropSet As PropertySet
oPropSet = _
ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
Try
	'try to get the iproperty value
	oTest = iProperties.Value("Custom", "DateTimeString")
Catch
	'catch error when iproperty doesn't exist and create it
	oPropSet.Add("", "DateTimeString")
End Try
'then set the property
iProperties.Value("Custom", "DateTimeString") = Time.ToString(Format)
RasmusBredal
@jonathanand if you want month and day to be shown with zero:
Dim Format As String = "yyyyMMddHHmm"
https://msdn.microsoft.com/en-us/library/8kb3ddd4(v=vs.110).aspx
jonathan
Perfect,
Would have been my next question.
Thank you
jonathan
Hello Curtis,
Thank you for your quick post and an awesome ilogic snippet!
hwu
Catch
End Try
Now it can be simplifed:
Catch
oPropSet.Add(Date.Now, "DateTimeString")
End Try
Miguel.CarvajalS34Q6
thanks, but the code does not work, it must be some restiction that windows has
