Change dxf export options in macro
適用対象外
1,337件の閲覧回数
8件の返信
メッセージ1/9
適用対象外
I have a macro that looks through an assembly and creates drawings based off of the flat patterns for sheet metal parts and then exports them as dxf's.  I was wondering if there was a way to change the dxf export settings so that it puts all the interior and outer profiles on one layer and puts up and down bends on the same layer.  I also want it to omit tangent lines and arc centers.  I don't know if this is possible but any help would be greatly appreciated.
0 件のいいね
解決済み
1,338件の閲覧回数
8件の返信
返信 (8)
メッセージ2/9
適用対象外
Someone corrected me on a different post so I just want to clarify that this is actually a Ilogic rule not a macro.
Here is the rule.
'define the active document as an assembly file
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4)
'check that the active document is an assembly file
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
	MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
	Exit Sub
End If
'get user input
RUsure = MessageBox.Show ( _
"This will create a DXF file for all of the asembly components that are sheet metal." _
& vbLf & "This rule expects that the part file is saved." _
& vbLf & " " _
& vbLf & "Are you sure you want to create DXF for all of the assembly components?" _
& vbLf & "This could take a while.", "iLogic  - Batch Output DXFs ",MessageBoxButtons.YesNo)
If RUsure = vbNo Then
	Return
	Else
End If
oPath = ThisDoc.Path
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
'get DXF target folder path
oFolder = oPath & "\" & oAsmName & " DXF Files"
'Check for the DXF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
End If
'- - - - - - - - - - - - -Component  - - - - - - - - - - - -
'look at the files referenced by the assembly
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
'work the the drawing files for the referenced models
'this expects that the model has been saved
		For Each oRefDoc In oRefDocs
			iptPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "ipt"
    		'check that model is saved
			If(System.IO.File.Exists(iptPathName)) Then
                Dim oDrawDoc As PartDocument
                oDrawDoc = ThisApplication.Documents.Open(iptPathName, True)
            	oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName))
				Try
                	'Set the DXF target file name
                	oDataMedium.FileName = oFolder & "\" & oFileName & ".dxf"
					Dim oCompDef As SheetMetalComponentDefinition
					oCompDef = oDrawDoc.ComponentDefinition
					If oCompDef.HasFlatPattern = False Then
						oCompDef.Unfold
					Else
   						oCompDef.FlatPattern.Edit
					End If
					Dim sOut As String
					sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=IV_OUTER_PROFILE"
					oCompDef.DataIO.WriteDataToFile( sOut, oDataMedium.FileName)
					'just for check its works coretcly
					'i=MessageBox.Show(oDataMedium.FileName, "Title",MessageBoxButtons.OKCancel)
					'MessageBox.Show(i,"title",MessageBoxButtons.OK)
					'If i=2 Then
						'Exit Sub
					'End If
					oCompDef.FlatPattern.ExitEdit
				Catch
				End Try
				oDrawDoc.Close
			Else
			End If
		Next
0 件のいいね
メッセージ3/9
適用対象外
I did some more reading and realized that what I want is a macro and not an Ilogic rule so if anyone could help modify this to work as a macro that would be extra helpful.
0 件のいいね
メッセージ4/9
適用対象外
解決済み
Anyone else looking for an answer to this, if you manually export as dxf you can then change the layers and other settings and save it so it does it on all future exports.
0 件のいいね
メッセージ5/9
chandra.shekar.g
Autodesk Support
Autodesk Support
解決済み
@Anonymous,
Hoping that below VBA macro may be helpful.
Sub Export_Sheetmetal()
    Set oAsmDoc = ThisApplication.ActiveDocument
    Dim oAsmName As String
    oAsmName = Left(oAsmDoc.displayname, Len(oAsmDoc.displayname) - 4)
        MsgBox ("Please run this rule from the assembly file.")
        Exit Sub
    End If
    'get user input
    Result = MsgBox("This will create a DXF file for all of the asembly components that are sheet metal." _
    & vbLf & " " _
    & vbLf & "This could take a while.", vbYesNo, "iLogic  - Batch Output DXFs ")
    If Result = vbNo Then
        Exit Sub
    End If
    Dim oPath As String
    Dim iSplit As Integer
    iSplit = InStrRev(oAsmDoc.FullDocumentName, "\")
    oPath = Left(oAsmDoc.FullDocumentName, iSplit - 1)
    Dim oDataMedium As DataMedium
    Set oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
    Dim oContext As TranslationContext
    Set oContext = ThisApplication.TransientObjects.CreateTranslationContext
    Dim oOptions As NameValueMap
    Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap
    Dim oFolder As String
        System.IO.Directory.CreateDirectory (oFolder)
    End If
    Set oRefDocs = oAsmDoc.AllReferencedDocuments
    Dim iptPathName As String
        If oRefDoc.DocumentSubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
            Set oDrawDoc = ThisApplication.Documents.Open(oRefDoc.FullDocumentName, True)
            oFileName = Left(oRefDoc.displayname, Len(oRefDoc.displayname) - 4)
            Set oCompDef = oDrawDoc.ComponentDefinition
                oCompDef.Unfold
            Else
            End If
            Dim sOut As String
            Call oCompDef.DataIO.WriteDataToFile(sOut, oFolder & "\" & oFileName & ".dxf")
            'If i=2 Then
                'Exit Sub
            'End If
            oDrawDoc.Close
        End If
    Next
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
メッセージ6/9
wCorreiaHBYAR
Hi Chandra, It shows error on this a line: "If Not System.IO.Directory.Exists(oFolder) Then"
Please let know if there is a quick fix for this one.
0 件のいいね
メッセージ7/9
chandra.shekar.g
Autodesk Support
Autodesk Support
@wCorreiaHBYAR,
Code should be fine. Please make sure that "oFolder" does not contain any special character in it.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
0 件のいいね
メッセージ8/9
wCorreiaHBYAR
Thank you Chandra, there are no special letters.
0 件のいいね
メッセージ9/9
kelvincosta
could you please share the original macro that looks throuhg the assembly and create the dxf file. I need those dxf file with the flat pattern face to send to my supplier to cut the plates
0 件のいいね
