Change background , save and change background to original using VB. NET
5 REPLIES 5
Joos_T
596 Views, 5 Replies
Dear all,
I want to save my thumbnails with a different background then my original setting of my inventor file.
Theirfore I first want to change the background then save the file and then set the setting back to the original inventor setting.
I've already have tried to write a little in Visual Studio, see attachment, but I keep getting an error.
It would be great if anyone could help me.
	Public Sub BackgroundSwapper(ByVal InventorApplication As Inventor.Application)
		Dim oDoc As Inventor.Document = InventorApplication.ActiveEditDocument
		Dim StandardFile As String = ("C:\TEMP\InventorBackGroundSettings.txt")
		Dim CurrentColorScheme As String
		On Error Resume Next
		CurrentColorScheme = InventorApplication.ActiveColorScheme.Name
		Dim DefaultSetting As String
		If System.IO.File.Exists(StandardFile) Then
			DefaultSetting = com_BackgroundAssm.Text
		Else
		End If
		If CurrentColorScheme = "Presentation" Then
			InventorApplication.ColorSchemes(DefaultSetting).Activate()
			InventorApplication.ColorSchemes.BackgroundType = 52737 '= color gradient.
		Else
			InventorApplication.ColorSchemes("Presentation").Activate()
			InventorApplication.ColorSchemes.BackgroundType = 52737 '= one color.
		End If
		oDoc.Save()
	End Sub
Labels (5)
5 REPLIES 5
Dev_rim
in reply to: Joos_T
Hi there,
As far as I know ActiveEditDocument, is using for reaching the assembly documents on the edit mode. So first thing you should use ActiveDocument instead of ActiveEditDocument.
I can not understand why you are using 2 If statements with the same result on true and false.
In the end the final code you need I think :
		Dim oDoc As Inventor.Document = InventorApplication.ActiveDocument
		Dim DefaultSetting As String = com_BackgroundAssm.Text
		oDoc.Save()
        InventorApplication.ColorSchemes(CurrentColorScheme).Activate()
	End Sub
If my answer is solved your problem, please mark it as Solution
Freundliche Grüße / Kind Regards
Joos_T
in reply to: Dev_rim
Thanks for your reply. It still has the same error as before.
I think your right about the double statement. So  I will implement that.
Dev_rim
in reply to: Joos_T
Oh I just check the image you send.
You have to call the function with Application object.
You are calling it right now like this
But you have to put some Application object inside of the parenthesis.
like:
BackgroundSwapper(Invapp)
or the variable that contains the Inventor.Application object.
Thats your issue
lah29-bertrand
in reply to: Joos_T
for myself, I use this little code
In application option: one color set to white
and I use background file
If ThisApplication.ColorSchemes.BackgroundType = kOneColorBackgroundType Then
ThisApplication.ColorSchemes.BackgroundType = kImageBackgroundType
Else If ThisApplication.ColorSchemes.BackgroundType = kImageBackgroundType Then
End If
Joos_T
The code does work. I only had to change "Presentation" to a variable (com_backgroundassm)
Now it will change to the variable you choose in the combobox.
thanks a lot!
