This rule shown below was working well (several times) last night.
Today morning, it keeps giving me an error message: Could someone help me, please.
Imports System.Windows.Forms Sub Main() 'https://forums.autodesk.com/t5/inventor-customization/ilogic-move-body-from-point-to-coordinate/td-p/8222376 'https://forums.autodesk.com/t5/inventor-customization/selectionfilterenum-enumerator-for-center-of-arc-or-circle/m-p/8556328 'Dim myPoint = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPointEntities, "Select Point to set as origin:") Dim iLNO As String = "0004" Clipboard.SetText("TEST") oDoc = ThisApplication.ActiveDocument oCompDef = oDoc.ComponentDefinition oMidX = 0 oMidY = 0 oMidZ = 0 oSV = "Single Vertex" oMP = "Middle Point" oCP = "Center point of Arc or Circle" oCancel = "Cancel" Dim oPoint_Type As New ArrayList 'oPoint_Type.Add(oSV) 'oPoint_Type.Add(oMP) oPoint_Type.Add(oCP) oPoint_Type.Add(oCancel) oCP_Other_Y = "Yes" oCP_Other_N = "No" oCP_Other_YN = oCP_Other_Y oPoint_Type_X = InputListBox("Prompt", oPoint_Type, oPoint_Type(0), Title := iLNO & ": Options", ListName := iLNO & ": List") If oPoint_Type_X = oCP Then oCP_Other_YN = oCP_Other_N If oPoint_Type_X = oCancel Then Exit Sub If oPoint_Type_X = "Middle Point" Then oIterate = 2 oDivider = 2 Else oIterate = 1 oDivider = 1 End If For i = 1 To oIterate If i = 1 Then oTitle_MP = "Select Point(Vertex) - 1st" If i = 2 Then oTitle_MP = "Select Point(Vertex) - 2nd" 'Dim oPoint_SV = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPointEntities, "Select a Point (vertex)") 'Dim oPoint_MP = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPointEntities, oTitle_MP) 'Dim oArc = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllCircularEntities, "Select a Center Point (Arc or Circle)") L_oPoint: If oPoint_Type_X = oSV Then Dim oPoint_SV = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPointEntities, "Select a Point (vertex)") oPoint = oPoint_SV Else If oPoint_Type_X = oMP Then Dim oPoint_MP = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPointEntities, oTitle_MP) oPoint = oPoint_MP End If If oCP_Other_YN = oCP_Other_Y Then If IsNothing(oPoint) Then GoTo L_oPoint: End If If oPoint_Type_X = oCP Then oPoint_Str = oCP_Sub() 'specify word splitting characters "space" and "dash" Dim Separators() As Char = {","c} Sentence = oPoint_Str Words = Sentence.Split(Separators) i = 0 For Each wrd In Words ' MessageBox.Show("Word Index #" & i & " = " & Words(i)) i += 1 Next oMidX = Val(Words(0))/2.54 oMidY = Val(Words(1))/2.54 oMidZ = Val(Words(2))/2.54 End If If oCP_Other_YN = oCP_Other_Y Then myPoint = oPoint.Point oMidX = (myPoint.X/2.54 + oMidX) oMidY = (myPoint.Y/2.54 + oMidY) oMidZ = (myPoint.Z/2.54 + oMidZ) End If Next i oMidX = oMidX / oDivider oMidY = oMidY / oDivider oMidZ = oMidZ / oDivider oWP_Cordinates = oMidX.ToString & " " & oMidY.ToString & " " & oMidZ.ToString '____Create and write to a text file_________________ oWrite = System.IO.File.CreateText(ThisDoc.PathAndFileName(False) & ".txt") oWrite.WriteLine("oMidX: " & oMidX) oWrite.WriteLine("oMidY: " & oMidY) oWrite.WriteLine("oMidZ: " & oMidZ) oWrite.WriteLine(oMidX & " " & oMidY & " " & oMidZ) oWrite.WriteLine(oWP_Cordinates) oWrite.Close() 'open the file ThisDoc.Launch(ThisDoc.PathAndFileName(False) & ".txt") ThisApplication.ActiveView.Fit oCreateWP(oMidX,oMidY,oMidZ) oClipboard = CStr(oMidX) & "," & CStr(oMidY) & "," & CStr(oMidZ) Clipboard.SetText(oClipboard) End Sub Sub oCreateWP(oMidX, oMidY, oMidZ) oUCF = 2.54 oMidX = oMidX*oUCF oMidY = oMidY*oUCF oMidZ = oMidZ*oUCF Dim oDoc As Document oDoc = ThisApplication.ActiveDocument Dim oTG As TransientGeometry oTG = ThisApplication.TransientGeometry Dim oWorkPoint As WorkPoint 'create a workpoint oWorkPoint = oDoc.ComponentDefinition.WorkPoints.AddFixed(oTG.CreatePoint(oMidX,oMidY,oMidZ)) 'display the new workpoint's coordinates MessageBox.Show(oWorkPoint.Point.X/2.54 &", "& oWorkPoint.Point.Y/2.54 &", "& oWorkPoint.Point.Z/2.54, "@ SUB oCreateWP") End Sub Sub oAssign_from_Clipboard() Dim Len_Max As Double Len_Max = Convert.ToDouble(Clipboard.GetText) 'To assgn clipboard value (numerical) to the variable Dim oMfgr As String oMfgr = Clipboard.GetText 'To assgn clipboard value (string) to the variable End Sub Function oCP_Sub() 'rivate Sub TestGetCenter() 'Function oCP_Sub(oArc) 'https://forums.autodesk.com/t5/inventor-customization/find-center-point-coordinate-of-arc-or-circle/td-p/2630752 Dim GetCenterPoint As Point Count_NotSelected = 0 L_oArc : Dim InputEdge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllCircularEntities, "Select a Point (vertex):") If InputEdge Is Nothing Then Count_NotSelected += 1 If Count_NotSelected > 3 Then 'To help if no crcular features to select Exit Function Else GoTo L_oArc : End If End If 'prop = customPropertySet.Item(oCustiProperties_Array.Item(i)) Select Case InputEdge.GeometryType Case kCircularArcCurve Dim arc As Arc3d arc = InputEdge.Geometry GetCenterPoint = arc.Center Case kCircleCurve Dim circ As Inventor.Circle circ = InputEdge.Geometry GetCenterPoint = circ.Center Case kEllipticalArcCurve Dim ellipArc As EllipticalArc ellipArc = InputEdge.Geometry GetCenterPoint = ellipArc.Center Case kEllipseFullCurve Dim ellipse As EllipseFull ellipse = InputEdge.Geometry GetCenterPoint = ellipse.Center Case Else GetCenterPoint = Nothing End Select MessageBox.Show("@ end of Function oCP_Sub", "Title") MsgBox("Center @ oCP_Sub: " & GetCenterPoint.X/2.54 & ", " & GetCenterPoint.Y/2.54 & ", " & GetCenterPoint.Z/2.54) Return (GetCenterPoint.X & "," & GetCenterPoint.Y & "," & GetCenterPoint.Z) End Function
Solved by JaneFan. Go to Solution.
Thanks for the reply. It works well (always) on my Inventor 2019 Professional home office installation.
But, at another location using Inventor 2018 Professional, it keeps giving me the error always. STILL THE SAME with this 2018 installation.
Same for the following rule (works in 2019, but not in 2018). Could you reply with comments.
Sub Main() 'rivate Sub TestGetCenter() iLNO = "0005PA" 'https://forums.autodesk.com/t5/inventor-customization/find-center-point-coordinate-of-arc-or-circle/td-p/2630752 Dim oCenter As Point Count_NotSelected = 0 L_oArc: Dim InputEdge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllCircularEntities, "Select a Point (vertex):") If InputEdge Is Nothing Then Count_NotSelected += 1 If Count_NotSelected > 3 Then 'To help if no crcular features to select Exit Sub Else GoTo L_oArc : End If End If Select Case InputEdge.GeometryType Case kCircularArcCurve MessageBox.Show("Message1", "Title") Dim arc As Arc3d arc = InputEdge.Geometry GetCenterPoint = arc.Center Case kCircleCurve MessageBox.Show("Message2", "Title") Dim circ As Inventor.Circle circ = InputEdge.Geometry GetCenterPoint = circ.Center Case kEllipticalArcCurve MessageBox.Show("Message3", "Title") Dim ellipArc As EllipticalArc ellipArc = InputEdge.Geometry GetCenterPoint = ellipArc.Center Case kEllipseFullCurve MessageBox.Show("Message4", "Title") Dim ellipse As EllipseFull ellipse = InputEdge.Geometry GetCenterPoint = ellipse.Center Case Else MessageBox.Show("Message5", "Title") GetCenterPoint = Nothing End Select oCenter = GetCenterPoint MsgBox ("Center: " & oCenter.X & ", " & oCenter.Y & ", " & oCenter.Z) End Sub
Hey @RoyWickrama_RWEI ,
I see the reason now. It can be solved by adding the enum type before the value. Without adding the enum type, we can see it always went to case else and GetCenterPoint is always nothing in inventor 2018, so that error happens when trying to output its X, Y and Z using Msgbox().
It is safe and recommended to add enum type in front anytime using enum value. Please update code like this:
Sub Main() 'rivate Sub TestGetCenter() iLNO = "0005PA" 'https://forums.autodesk.com/t5/inventor-customization/find-center-point-coordinate-of-arc-or-circle/td-p/2630752 Dim oCenter As Point Count_NotSelected = 0 L_oArc: Dim InputEdge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllCircularEntities, "Select a Point (vertex):") If InputEdge Is Nothing Then Count_NotSelected += 1 If Count_NotSelected > 3 Then 'To help if no crcular features to select Exit Sub Else GoTo L_oArc : End If End If Select Case InputEdge.GeometryType Case CurveTypeEnum.kCircularArcCurve MessageBox.Show("Message1", "Title") Dim arc As Arc3d arc = InputEdge.Geometry GetCenterPoint = arc.Center Case CurveTypeEnum.kCircleCurve MessageBox.Show("Message2", "Title") Dim circ As Inventor.Circle circ = InputEdge.Geometry GetCenterPoint = circ.Center Case CurveTypeEnum.kEllipticalArcCurve MessageBox.Show("Message3", "Title") Dim ellipArc As EllipticalArc ellipArc = InputEdge.Geometry GetCenterPoint = ellipArc.Center Case CurveTypeEnum.kEllipseFullCurve MessageBox.Show("Message4", "Title") Dim ellipse As EllipseFull ellipse = InputEdge.Geometry GetCenterPoint = ellipse.Center Case Else MessageBox.Show("Message5", "Title") GetCenterPoint = Nothing End Select oCenter = GetCenterPoint If Not oCenter Is Nothing Then MsgBox ("Center: " & oCenter.X.ToString() & ", " & oCenter.Y.ToString() & ", " & oCenter.Z.ToString()) End If End Sub
Thanks a lot. Great fix. It is working on my 2018 installation as well.
I will continue to build up the main rule and add more functionality (e.g. to pick more points, ..)
Again, THANKS.
