Tried messing around with this yesterday. I first created a sketch line and patterned points along it. Then created the sketch + block for the first point. Seems to work fine. Connecting the sketches w/ a 3d sketch could be challenging.
Sub Main
' Get the transaction manager from the application
Dim oTxnMgr As TransactionManager
oTxnMgr = ThisApplication.TransactionManager
' Start a regular transaction
Dim oTxn As Transaction
oTxn = oTxnMgr.StartTransaction(ThisDoc.Document, "undo")
Dim oPDoc As PartDocument = ThisApplication.ActiveDocument
Dim oPDef As PartComponentDefinition = oPDoc.ComponentDefinition
Dim oPoint2d As Point2d = ThisApplication.TransientGeometry.CreatePoint2d()
Dim startRotation As Double = 0
Dim endRotation As Double = 222
For i = 4 To oPDef.WorkPlanes.Count
Dim oWorkPlane As WorkPlane = oPDef.WorkPlanes(i)
'oWorkPlane.SetByNormalToCurve(oPDef.Sketches3D.Item(1), oPDef.WorkPoints.Item(i - 2))
'oWorkPlane.SetByNormalToCurve(oPDef.Sketches3D.Item(1).SketchEntities3D(1), oPDef.WorkPoints.Item(i - 2))
RotateBlock(oPDef.Sketches.Item(i - 3), i - 3, startRotation, endRotation)
Next
For i = oPDef.WorkPlanes.Count - 3 To oPDef.WorkPoints.Count - 2
Dim oWorkPlane As WorkPlane = oPDef.WorkPlanes.AddByNormalToCurve(oPDef.Sketches3D.Item(1).SketchEntities3D(1), oPDef.WorkPoints(i + 2))
Dim oSketch2 As PlanarSketch = oPDef.Sketches.Add(oWorkPlane, False)
oSketch2.SketchBlocks.AddByDefinition(oPDef.SketchBlockDefinitions(1), oPoint2d)
Dim oSketchEntity As SketchEntity = oSketch2.AddByProjectingEntity(oPDef.WorkPoints(i + 2))
Dim oInsSpt As SketchPoint = oSketch2.SketchBlocks(1).GetObject(oSketch2.SketchBlocks(1).Definition.InsertionPoint)
oSketch2.GeometricConstraints.AddCoincident(oInsSpt, oSketchEntity)
RotateBlock(oPDef.Sketches.Item(i + 1), i + 2, startRotation, endRotation)
Next
ThisDoc.Document.Rebuild
oTxn.End
End Sub
Sub RotateBlock(oSketch As PlanarSketch, SketchNumb As Integer, startRotation As Double, endRotation As Double)
'https://forums.autodesk.com/t5/inventor-programming-ilogic/rotate-sketchblock-in-sketch/td-p/9684760
Dim oSBlock As SketchBlock = oSketch.SketchBlocks(1)
Dim oOrgMatrix As Matrix2d = oSBlock.Transformation.Copy
Dim oOPoint As Point2d
Dim oXAxis, oYAxis As Vector2d
oOrgMatrix.GetCoordinateSystem(oOPoint, oXAxis, oYAxis)
Dim oAngle As Double = (endRotation - startRotation) * (SketchNumb / (oSketch.Parent.WorkPoints.Count - 1)) Mod 360
Dim oRad As Double = (oAngle / 180) * PI
oOrgMatrix.SetToRotation(oRad, oOPoint)
oSBlock.Transformation = oOrgMatrix
End Sub
