Hi
Here's something I've never seen before:
When I try to remove an event handler from a part file and hit 'OK', I get this message, and the handler isn't removed.
I've tried removing it manually and programmatically, but both result in presumably the same error.
Any ideas?
Solved by meGVGMF. Go to Solution.
Oh I figured it out.
A coworker had inserted a content centre part as custom, and I thought it was one of ours. We've been adding event handlers to these somewhat blindly (with a script that manages the dialog for us, but the results of which we can't directly see), and so being able to see the event handler dialog I figured it was just a normal part that was broken, when really it was being protected from changes by Inventor.
Edit: Actually that didn't seem to be it. I tried reproducing the error and couldn't. It may simply have been the property set, or the file anyway, was corrupted, and wouldn't allow any changes. I simply deleted the generated content centre part file and placed it back in the assembly to regenerate it, and everything's fine.
