I'm attempting to access the event triggers through a c# add-in.
When I do a foreach on the document.PropertySets object, I only see the four standard property sets, although my document has four triggers set.
What am I missing?
Solved by Michael.Navara. Go to Solution.
The iLogic events property set is hidden because it starts with underscore.
Its display name is "_iLogicEventsRules" and internal name "{2C540830-0723-455E-A8E2-891722EB4C3E}". Both of them can be used to localize this property set.
Thank you.
propset1["{2C540830-0723-455E-A8E2-891722EB4C3E}"].Name returns _iLogicEventsRules.
I'm a little curious about this 'hidden' aspect. What other things might be hidden and how would I find them?
Now I just look into my documentation notes. 😀
But when I needed to find it, I had to open the IPT file in a binary editor and look through the mess to find something useful. If you want to try it, I tell you there is one more property set related to iLogic.
