Can I use iLogic to write a description similar to how the "<>" works in the iproperties "description"?
chris
chris
I am wondering how to create a description from parameters and regular text similar to how you are able to create descriptions in the iProperties "Description" slot.
Description example: =<TUBING, SQUARE <Width> X <Height> X <Length> LONG
how would I write this same type of "description" in iLogic using the parameters (Width, Height, Length) and the plain text of TUBING, SQUARE & Long)
Replies (8)
tyler.warner
How about something like this. The underscores are to break the text into multiple lines.
iProperties.Value("Project", "Description") = "<TUBING, SQUARE <" _
& Parameter("Width") _
& "> X <" & Parameter("Height") _
& "> X <" & Parameter("Length") _
& "> LONG"
If this solved your problem or answered your question, please click ACCEPT SOLUTION.
If this helped you, please click LIKE.
Curtis_Waguespack
Hi @chris
I don't think you can insert the Parameters to be a "live" formula in this way, instead you must use iproperties.
Meaning that if you use Parameters it will simply get the value of the parameter at the moment, and will not update the description if the parameter changes in the future ( unless the rule runs).
What you can do though is export the parameter as an iProperty:
Then you can use something like this to set the formula in the description:
iProperties.Value("Project", "Description") = _
"= TUBING, SQUARE <Width> X <Height> X <Length> LONG"
This will give you a result such as this:
Recall that you can format the way the parameter export by right clicking them as shown:
And then using these options:
I hope this helps.
Curtis
chris
@Curtis_Waguespack Yes, this is how I have always done this, except last night it wasn't working.
see video
chris
what I want to do with the square / Rect tubing is to have the parameter "Shape" be available in the description... but it's not working
A.Acheson
If the parameter is a text parameter this won't work directly because of the lack of export option to iproperty.
You need the ilogic rule first to create a custom iproperty and set it to the parameter value.
iProperties.Value("Custom", "Shape") = Shape
What is being used in the forumula is not the parameter but rather the iproperty name either.
Regards
Alan
chris
@A.Acheson @Curtis_Waguespack @tyler.warner
Tyler, I've never seen the "case" word in iLogic, what is that?
A.Acheson
Here is how to remove unit identifier for inches [ " ]  from a string. Use the string function replace.
1. Populate Description by code
'Trigering Criteria, Local Parameters are only used to trigger the rule to run.
a = Width
b = Height
c = Thk
'Replaces " with Empty String.
Dim width As String = iProperties.Value("Custom", "Width").ToString.Replace("""", "")
Dim height As String = iProperties.Value("Custom", "Height").ToString.Replace("""", "")
Dim thk As String = iProperties.Value("Custom", "Thk").ToString.Replace("""", "")
'Set Description iproperty.
iProperties.Value("Project", "Description") = "L " & width & " x " & height & " x " & thk & " x "
 Result:
2. Populate Description by expression:
= L <Width> X <Height> X <Thk>
a = Width
b = Height
c = Thk
iProperties.Value("Custom", "Width") = iProperties.Value("Custom", "Width").ToString.Replace("""", "")
iProperties.Value("Custom", "Height") = iProperties.Value("Custom", "Height").ToString.Replace("""", "")
iProperties.Value("Custom", "Thk") = iProperties.Value("Custom", "Thk").ToString.Replace("""", "")
Triggering this rule was a lot trickier than I had imagined.
What did Work:
It is necessary to have the local parameters in the rule in order for the rule to be automatically triggered on parameter change.
What didn't work:
  • Simply setting the rule to run on the event trigger of change of iproperties did not work. Changing the parameter and exporting the parameter is not considered a change to iproperty it seems.
Regards
Alan
chris
FYI, I got it figured out !!!!!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
