is it possible to change the name of the drawing sheet for the name of the part that is inserted into the drawing?
Solved by WCrihfield. Go to Solution.
Hi @Miguel.CarvajalS34Q6. Yes. Here is a fairly simple iLogic rule which will do that for the active sheet of a drawing, as long as that sheet's first view is referencing a model document.
oDDoc = ThisDrawing.Document
oSheet = oDDoc.ActiveSheet
If oSheet.DrawingViews.Count = 0 Then Exit Sub
Dim oView As DrawingView = oSheet.DrawingViews.Item(1)
oModelDispName = oView.ReferencedDocumentDescriptor.DisplayName
oSheet.Name = oModelDispName
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
