Hi
I would like to show the part property "material" on my drawing with a script. But the script also need to check that there are only one part and no assembly shown on the drawing views. Is it possible?
BR/Goran
Solved by Cadkunde.nl. Go to Solution.
Hi @Gwennberg. Sure sounds possible to me. Do you want this note on the drawing to just contain the simple name of the parts material, or do you want that note to be 'linked' to the 'Material' iProperty in the model. Anything else special about this note? Is this just going to be a general note somewhere on the sheet, or is it going to be within a BorderDefinition Sketch, or within a TitleBlockDefinition sketch? Any other text within the note, before or after the name of the material? If there is an assembly found within the drawing, should it just do nothing then, or place some other note?
Wesley Crihfield
(Not an Autodesk Employee)
You could do that with this code:
Class Event_BeforeSave_Drawing Shared oDoc As Document Shared modeldoc As Document Shared partdoc As PartDocument Sub Main() oDoc = ThisDoc.Document If Not oDoc.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then Exit Sub modeldoc = ThisDrawing.ModelDocument If modeldoc Is Nothing Then Exit Sub If Not modeldoc.documenttype = DocumentTypeEnum.kPartDocumentObject Then Exit Sub If oDoc.ReferencedDocuments.Count > 1 Then Exit Sub partdoc = modeldoc '''Names can be found at: https://modthemachine.typepad.com/my_weblog/2010/02/accessing-iproperties.html UpdateProperty("Inventor User Defined Properties", "Material", partdoc.ActiveMaterial.DisplayName) End Sub Sub UpdateProperty(propset As String, propname As String, propvalue As String) Try oDoc.PropertySets.Item(propset).Item(propname).Value = propvalue Catch oDoc.PropertySets.Item(propset).Add(propvalue, propname) End Try End Sub End Class
However, I prefer to add material in the title block (or sketched symbol), when you reference to an assembly it remains empty (except welded assemblies, but you could add a material for that named "-"
This is what I had in mind, if we were talking about a regular GeneralNote on the 'active' sheet (and not within a border or title block), and with the value being 'linked'. Just one way among many.
If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
MsgBox("A Drawing document must be active for this code to work. Exiting.", vbCritical, "")
Exit Sub
Dim oDDoc As DrawingDocument = ThisDoc.Document
Dim oRefDocs As DocumentsEnumerator = oDDoc.ReferencedDocuments
If oRefDocs.Count = 0 Or oRefDocs.Count > 1 Then Exit Sub
Dim oRefDoc As Document = oRefDocs.Item(1)
If oRefDoc.DocumentType <> DocumentTypeEnum.kPartDocumentObject Then Exit Sub
Dim oPDoc As PartDocument = oRefDoc
Dim oPSet As PropertySet = oPDoc.PropertySets.Item(3)
Dim oProp As Inventor.Property = oPSet.Item("Material")
Dim oMaterial As String = oProp.Value
Dim oGNotes As GeneralNotes = oDDoc.ActiveSheet.DrawingNotes.GeneralNotes
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim oP2d As Point2d = oTG.CreatePoint2d(3, 3)
Dim oFText As String = "<Property Document='model' PropertySet='" & oPSet.Name & "' Property='" & oProp.Name & "' FormatID='" & oPSet.InternalName & "' PropertyId='" & oProp.PropId & "' />"
Dim oNote As GeneralNote = oGNotes.AddFitted(oP2d, oFText)
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
Many thanks. I have the material property in the title block and with this script I got the material to the part shown in the drawing. Great!
I was trying to figure out how to make the "/" symbol appear when there was an assembly, "two or more parts" or exploded view but I can't figure out where to change the code. Wish I could learn iLogic..
Do you have any tips where I can start learning programming? Website, youtube, book.
//Goran
Here is a link to an article I put together to help out with this goal.
Learning about Inventor's iLogic
Wesley Crihfield
I took a course vb.net/ilogic of 4 days. Then just make small script within comfortzone or with 1 - 2 challanges raising the bar. keeping it fun and not frustrating. Slowly stepping up. And after a few years anything is possible.
At first, dont mind the googling and copy pasting and adjust it till you understand it
