C# API Occurences iProperties Projekt
4 REPLIES 4
christoph.steidle
320 Views, 4 Replies
christoph.steidle
Hello all,
I have been searching here in the forum for a long time but unfortunately have not yet found a solution.
Is there a way to access the iProperties/project via the API and query the values?
I have the following code but I don't know which function I can use to query it.
Row 22 I try to search for it but it doesn'twork.
private static void GetOccurences(ComponentOccurrences componentOccurrences, int level, IProgressTracker tracker, CancellationToken token)
        double count = 0;
        int numberOfAllObjects = componentOccurrences.Count;
        foreach (ComponentOccurrence occurence in componentOccurrences)
            Functions.ProgressBar.CancelJob(tracker, token);
            //MassProperties
            var massProperties = occurence.MassProperties;
            //RefKey
            byte[] myRefKey = { };
            occurence.GetReferenceKey(ref myRefKey, _createKeyContext);
            listRefKeys.Add(_documentAssembly.ReferenceKeyManager.KeyToString(myRefKey)); //RefKEy kontrollieren
            //GetProperties
            var name = occurence.ItemByName["Description"];
Many thanks for your help.
Greetings
Chris
Hello all,
        double count = 0;
            //MassProperties
            //RefKey
            //GetProperties
Greetings
Chris
4 REPLIES 4
JelteDeJong
Is this what you are looking for:
AssemblyDocument document = (AssemblyDocument)ThisDoc.Document;
ComponentOccurrence componentOccurrences = document.ComponentDefinition.Occurrences[1];
Document refDoc = (Document)componentOccurrences.Definition.Document;
// property (set) names can be found on:
// https://modthemachine.typepad.com/my_weblog/2010/02/accessing-iproperties.html
PropertySet propertySet = refDoc.PropertySets["Design Tracking Properties"];
Property property = propertySet["Project"];
string project = property.Value as string;
System.Diagnostics.Debug.WriteLine(project);
Jelte de Jong
Blog: hjalte.nl - github.com
Jelte de Jong
christoph.steidle
@JelteDeJong
Thank you very much for your answer.
I have just tested it in the way you suggested.
In "property" I get the following values displayed.
However, I would like to read out the designation (Beschreibung) as shown in the following picture.
I hope it is clear what I mean by this. 🙂
Thank you very much for your help.
Greetings
Chris
@JelteDeJong
Greetings
Chris
JelteDeJong
Have a look at this article.
at bottom you will find a table with the propery(set) names that you can use.
Jelte de Jong
Jelte de Jong
christoph.steidle
Thank you very much now it works! 🙂
