I change the part "levytyö_1" Item number to 200 by using this code.
Then renumber Item column by using this code.
Why this part "Levytyö_1" does not stay last in the row?
Solved by WCrihfield. Go to Solution.
Hi @manu.marjanen. In your second code, when you are looping through the BOMRows, the order of the looping doesn't go by the ItemNumber property's value. It's a bit hard to explain, but the natural order of a 'For Each' type of loop (or a For i = 1 To oGroup.Count type of loop) is usually whichever Item was created first, is the first to be processed, and the last Item created will be the last to be processed. If you want to loop through them based on their ItemNumber property value, you would have to set-up the code for the loop process differently. I hope this makes sense to you.
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS :light_bulb: or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
Have you tried using the renumbering method of the BOMView object?
Given that the structured view is enabled. This single row of code should renumber the BOM for you 🙂
ThisDoc.Document.ComponentDefinition.BOM.BOMViews(2).Renumber(1, 1)
Jhoel Forshav
Download my free Inventor Addin - Hole Projector
LinkedIn | Ideas | Contributions | Blog posts | Website
It can be complicated when trying to sort BOM rows in a custom way, then renumber them afterwards. The simplest way I can think of in this case would be to add each BOMRow to a SortedDictionary, with the ItemNumber as the Key for each row. A SortedDictionary is a type of variable/object that can hold many items/objects, each paired with a 'Key'. The 'Key' can then be used to find or sort the objects within the collection. In this case we want the rows to be sorted by their existing ItemNumber property, then we want to step through them in that order and change the ItemNumber value to a new incremental value. Here is the code I created for your custom situation.
Dim app As Inventor.Application = ThisApplication
Dim adoc As AssemblyDocument = app.ActiveDocument
Dim compDef As AssemblyComponentDefinition = adoc.ComponentDefinition
'create a variable to hold all BOMRows and their current ItemNumber value
Dim oRows As New SortedDictionary(Of Integer, Inventor.BOMRow)
'add each row to this collection
For Each oBOMRow As BOMRow In compDef.BOM.BOMViews(2).BOMRows
oRows.Add(CInt(oBOMRow.ItemNumber), oBOMRow)
Next
'they are already automatically sorted by their ItemNumber value now
'now we will change the ItemNumber value to the incremental value, in descending order
Dim Count As Integer = 0
For Each oRow As KeyValuePair(Of Integer, Inventor.BOMRow) In oRows
Count = Count + 1
'the oRow.Value is the BOMRow
oRow.Value.ItemNumber = Count
Next
This process will only work if the ItemNumber is an Integer (no alphabet characters or special characters).
Wesley Crihfield
