I have written code in C# to automatically export the correct fields of an assembly to the BOM, by importing an XML file with the right fields. When I do this manually, it works: the fields appear in the order I placed them. However, when my C# code is doing this, the order is not the same.
Correct is:
The export in Excel shows (with my code) this:
I thought it worked properly before, however I didn't change anything in my code, so most likely it was always like this and I didn't check.
Is there something I need to add to my code, is this a bug in the API? I recently updated to Inventor 2019.5.1. I will check if this also occurs on an older version.
This is the code:
public void XXXContentList()
string progId = "Inventor.Application";
Inventor.Application invApp = (Inventor.Application)Marshal.GetActiveObject(progId);
DocumentTypeEnum docType = invApp.ActiveDocumentType;
AssemblyDocument assemblyDoc;
AssemblyComponentDefinition assemblyCompDef;
BOM bom;
SaveFileDialog saveFileDialog = new SaveFileDialog();
if (docType == DocumentTypeEnum.kAssemblyDocumentObject)
assemblyDoc = (AssemblyDocument)invApp.ActiveDocument;
assemblyCompDef = assemblyDoc.ComponentDefinition;
else
return;
//templateName = "All avalaible fields";
saveFileDialog.FileName = "Content List.xlsx";
saveFileDialog.Filter = "Excel File (*.xlsx)|*xlsx";
string fullDocName = assemblyDoc.FullDocumentName;
string fileName = assemblyDoc.DisplayName;
try
var templateForm = new FormContentListSelect(this);
if (templateForm.ShowDialog() == DialogResult.OK)
var contentListTemplateName = string.Empty;
if (TemplateName == "All avalaible fields")
contentListTemplateName = "XXX_ContentListAll.xml";
else if (TemplateName == "Project Engineering Den Bosch")
contentListTemplateName = "XXX_ContentListProjectEngineeringDB.xml";
bom = assemblyCompDef.BOM;
bom.PartsOnlyViewEnabled = true;
bom.ImportBOMCustomization(System.IO.Path.GetDirectoryName(Assembly.GetCallingAssembly().Location) + @"\" + contentListTemplateName);
var bomView = bom.BOMViews["Parts Only"];
string initDirectory = fullDocName.Replace(fileName + ".iam", "");
string fileNameExcel = fileName + " Content List.xlsx";
string filePath = initDirectory + fileNameExcel;
saveFileDialog.InitialDirectory = initDirectory;
saveFileDialog.FileName = fileNameExcel;
if (saveFileDialog.ShowDialog() == DialogResult.OK)
bomView.Export(saveFileDialog.FileName, FileFormatEnum.kMicrosoftExcelFormat);
//EditExcel(saveFileDialog.FileName);
DialogResult dialogResult = MessageBox.Show("Would you like to open the created Content List?", "Open Content List", MessageBoxButtons.YesNo, MessageBoxIcon.Question);
if (dialogResult == DialogResult.Yes)
Process fileOpener = new Process();
fileOpener.StartInfo.FileName = saveFileDialog.FileName;
fileOpener.Start();
else if (templateForm.ShowDialog() == DialogResult.Cancel)
return;
catch
MessageBox.Show("Please save the assembly before generating the content list.", "Please save", MessageBoxButtons.OK, MessageBoxIcon.Exclamation);
I can confirm that issue is not arising when using Inventor 2021.
Using 2019.4.9 the problem is also present. I can later try on another pc that maybe has an even older version of 2019 than 2019.4.9.
I'm seeing the same thing in 2019.4.8. It appears that the API export ignores the column ordering. If you open the xml file in Visual Studio, you can see the complete list of columns, visible or not. Within a column element's definition there's a property element with the attribute named VisibleIndex. This should be the column ordering, except it looks like the API export ignores this. I was able to reorder the columns by moving a column's element up or down and resequencing the name="itemxx" attributes. Since it's not happening for you in 2021, I assume it's a glitch that Autodesk fixed only in later versions.
Parts only would be under layout index 2
Hope this helps.
Jeremy
This is a known issue going back as far as 2014 looking at the threads. Here is the post where the below solution is discussed. The work around is to reorder the excel columns in a separate operation after the BOM has been exported. Private Sub ReorderXLBOM() does the business. The xml is really only used to ensure the correct columns are exported. As a result the process is independent of the user's interaction with the headers in the BOM of each assembly. Although I am sure if you have custom columns this would need to be taken into account in the sort pattern, I assume you would need to export and read the xml to extract the header order and assign to excel sort sub routine.
AddReference "Microsoft.Office.Interop.Excel" 'To use excel Imports System.Windows.Forms Imports System.IO Imports Microsoft.Office.Interop.Excel 'To use excel Sub Main() Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument 'Dim oPath As String 'oPath = oFolderDlg 'oFileName = oPath & "Bruce.xml" ExportBOM(oDoc) End Sub Private BOMCustomizationFile As String = "C:\CustFile.xml" Private excelApp As Microsoft.Office.Interop.Excel.Application Private xlws As Worksheet Sub ExportBOM(oDoc As Document) 'File Path Creation/Processing 'Note, the following line will cause an error if the document is not saved. Dim oExportPath As String = System.IO.Path.GetDirectoryName(oDoc.FullFileName) & "\BOM\" Dim oExportName As String = oExportPath & System.IO.Path.GetFileNameWithoutExtension(oDoc.FullFileName) 'without extension'get BOM Target folder path If Not System.IO.Directory.Exists(oExportPath) Then: System.IO.Directory.CreateDirectory(oExportPath): End If If Dir(oExportName & ".xlsx") <> "" Then Kill (oExportName & ".xlsx") End If 'Inventor BOM Processing Dim oBOM As BOM = oDoc.ComponentDefinition.BOM oBOM.ImportBOMCustomization(BOMCustomizationFile) oBOM.StructuredViewEnabled = True oBOM.StructuredViewFirstLevelOnly = False Dim oStructuredBOMView As BOMView oStructuredBOMView = oBOM.BOMViews.Item("Structured") oStructuredBOMView.Export (oExportName & ".xlsx", kMicrosoftExcelFormat) 'Excel processing excelApp = CreateObject("Excel.Application") excelApp.Visible = True excelApp.DisplayAlerts = False wb = excelApp.Workbooks.Open(oExportName & ".xlsx") xlws = wb.Worksheets(1) Call ReorderXLBOM() excelApp.Columns.AutoFit excelApp = Nothing End Sub Private Sub ReorderXLBOM() Dim ndx As Integer Dim Found As Range Dim counter As Integer = 1 Dim arrColOrder() As String = {"Item", "QTY", "Part Number", "Description", "Stock Number"} 'arrColOrder = Array("Item", "QTY", "Part Number", "Description", "Stock Number") On Error Resume Next For ndx = LBound(arrColOrder) To UBound(arrColOrder) 'Set Found = xlws.Rows("1:1").Find(arrColOrder(ndx),, LookIn:=xlValues, LookAt:=xlWhole, SearchOrder:=xlByColumns, SearchDirection:=xlNext, MatchCase:=False) Found = xlws.Rows("1:1").Find(arrColOrder(ndx), , -4163, 1, 2, 1, False) If Err.Number <> 0 Then MsgBox ("Error With Excel FIND function: " & Err.Number & " :: " & Err.Description & vbLf & vbLf & ndx) Err.Clear End If If Not Found Is Nothing Then If Found.Column <> counter Then Found.EntireColumn.Cut xlws.Columns(counter).Insert(-4161) excelApp.CutCopyMode = False End If counter = counter + 1 End If Next If Err.Number <> 0 Then MsgBox ("Reorder Columns Rule Error: " & Err.Number & " :: " & Err.Description & vbLf & vbLf & ndx) Err.Clear End If End Sub Public Function oFolderDlg Dim dialog = New FolderBrowserDialog() ' dialog.SelectedPath = Application.StartupPath dialog.ShowNewFolderButton = True ' openFileDialog1.InitialDirectory If DialogResult.OK = dialog.ShowDialog() Then oPath = dialog.SelectedPath Else MsgBox("No File Selected. Aborting Rule") oPath = "" End If Return oPath End Function
I never noticed it before. Strange, but it is what it is then for now. We will probably switch to 2021 at the end of this year, so till that time we have to accept how it is.
