I need several BoM styles, so I've created several config XML files. For each style I have to Open BoM, clic on Import, then select the right xml file. It could be easier if I could create a macro "Open BoM with xxx.xml config file".
In a precedent version (I think 2010 or 2012), there was a "limitation" in the API, it was impossible to "Open BoM with options" or define BoM configuration (properties, ...) from a macro. Is it possible now ?
