BoM configuration
BoM configuration
TONELLAL
BoM configuration
TONELLAL
I need several BoM styles, so I've created several config XML files. For each style I have to Open BoM, clic on Import, then select the right xml file. It could be easier if I could create a macro "Open BoM with xxx.xml config file".
In a precedent version (I think 2010 or 2012), there was a "limitation" in the API, it was impossible to "Open BoM with options" or define BoM configuration (properties, ...) from a macro. Is it possible now ?
frederic.vandenplas
This is written in .NET and imports a XML file
Private Sub m_AmgBomImport_OnExecute(Context As NameValueMap) Handles m_AmgBomImport.OnExecute
Dim oAsmDoc As AssemblyDocument = InvApp.ActiveDocument
oAsmDoc.ComponentDefinition.BOM.ImportBOMCustomization("O:\~soft\autodesk customisatie\ribboninventor\AmgBomImport2015.xml")
End Sub
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
TONELLAL
Thanks, it's exactly what I was looking for : oAsmDoc.ComponentDefinition.BOM.ImportBOMCustomiza​tion(xml_config_file) and oAsmDoc.ComponentDefinition.BOM.ExportBOMCustomiza​tion (xml_config_file).
