Message 1 of 17
BOM API - Export application
Hello there,
I'm trying to create a BOM export method that is based on the API sample.
Spoiler
' Set a reference to the assembly document.
' This assumes an assembly document is active.
Dim oDoc As AssemblyDocument
Set oDoc = ThisApplication.ActiveDocument
Dim FirstLevelOnly As Boolean
If MsgBox("First level only?", vbYesNo) = vbYes Then
FirstLevelOnly = True
Else
FirstLevelOnly = False
' Set a reference to the BOM
Dim oBOM As BOM
Set oBOM = oDoc.ComponentDefinition.BOM
' Set whether first level only or all levels.
If FirstLevelOnly Then
oBOM.StructuredViewFirstLevelOnly = True
Else
oBOM.StructuredViewFirstLevelOnly = False
' Make sure that the structured view is enabled.
oBOM.StructuredViewEnabled = True
'Set a reference to the "Structured" BOMView
Dim oBOMView As BOMView
Set oBOMView = oBOM.BOMViews.Item("Structured")
Debug.Print "Item"; Tab(15); "Quantity"; Tab(30); "Part Number"; Tab(70); "Description"
Debug.Print "----------------------------------------------------------------------------------"
'Initialize the tab for ItemNumber
Dim ItemTab As Long
ItemTab = -3
Call QueryBOMRowProperties(oBOMView.BOMRows, ItemTab)
End Sub
Private Sub QueryBOMRowProperties(oBOMRows As BOMRowsEnumerator, ItemTab As Long)
ItemTab = ItemTab + 3
' Iterate through the contents of the BOM Rows.
Dim i As Long
For i = 1 To oBOMRows.Count
' Get the current row.
Dim oRow As BOMRow
Set oRow = oBOMRows.Item(i)
'Set a reference to the primary ComponentDefinition of the row
Dim oCompDef As ComponentDefinition
Set oCompDef = oRow.ComponentDefinitions.Item(1)
Dim oPartNumProperty As Property
Dim oDescripProperty As Property
If Typeof oCompDef Is VirtualComponentDefinition Then
'Get the file property that contains the "Part Number"
'The file property is obtained from the virtual component definition
Set oPartNumProperty = oCompDef.PropertySets _
.Item("Design Tracking Properties").Item("Part Number")
'Get the file property that contains the "Description"
Set oDescripProperty = oCompDef.PropertySets _
.Item("Design Tracking Properties").Item("Description")
Debug.Print Tab(ItemTab); oRow.ItemNumber; Tab(17); oRow.ItemQuantity; Tab(30); _
oPartNumProperty.Value; Tab(70); oDescripProperty.Value
Else
'The file property is obtained from the parent
'document of the associated ComponentDefinition.
Set oPartNumProperty = oCompDef.Document.PropertySets _
Set oDescripProperty = oCompDef.Document.PropertySets _
'Recursively iterate child rows if present.
If Not oRow.ChildRows Is Nothing Then
Call QueryBOMRowProperties(oRow.ChildRows, ItemTab)
Next
ItemTab = ItemTab - 3
End Sub
I made a simple modification in the "debug.print" area way at the end of the code. I added some code to write it into excel cells.
oWorkSheet.Range("B1").Value = oRow.ItemNumber
This works for these items. But.. at second I attempted to export the description like this:
Dim oDescripProperty As [Property]
'Get the file property that contains the "Description" oDescripProperty = oCompDef.Document.PropertySets_
.Item("Design Tracking Properties").Item("Description") oWorkSheet.Range("C" & y + i).Value = oDescripProperty
This result is NOT good, giving me this error when I run the code:
An unhandled exception of type 'System.Runtime.InteropServices.COMException' occurred in mscorlib.dll Additional information: Exception from HRESULT: 0x800A03EC
What I think is wrong is: the [Property] type cannot be exported into Excel. Seems fair. Then I tried to get it as string but here i'm at a loss. This is waht i tried:
oWorkSheet.Range("C" & y + i).Value = oDescripProperty.ToStringResult in Excel:
System.__ComObject
So basicly my question is:
How can i convert my [Property] variable into a string?
Thank you for reading.
I hope that I can resolve this issue quickly 🙂
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
