BOM API - Export application
Jef_E
Message 1 of 17
Jef_E
Hello there,
I'm trying to create a BOM export method that is based on the API sample.
Spoiler
 ' Set a reference to the assembly document.
    ' This assumes an assembly document is active.
    Dim oDoc As AssemblyDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim FirstLevelOnly As Boolean
    If MsgBox("First level only?", vbYesNo) = vbYes Then
        FirstLevelOnly = True
    Else
        FirstLevelOnly = False
    End If
    ' Set a reference to the BOM
    Dim oBOM As BOM
    Set oBOM = oDoc.ComponentDefinition.BOM
    ' Set whether first level only or all levels.
    If FirstLevelOnly Then
        oBOM.StructuredViewFirstLevelOnly = True
    Else
        oBOM.StructuredViewFirstLevelOnly = False
    End If
    ' Make sure that the structured view is enabled.
    oBOM.StructuredViewEnabled = True
    'Set a reference to the "Structured" BOMView
    Dim oBOMView As BOMView
    Set oBOMView = oBOM.BOMViews.Item("Structured")
    Debug.Print "Item"; Tab(15); "Quantity"; Tab(30); "Part Number"; Tab(70); "Description"
    Debug.Print "----------------------------------------------------------------------------------"
    'Initialize the tab for ItemNumber
    Dim ItemTab As Long
    ItemTab = -3
    Call QueryBOMRowProperties(oBOMView.BOMRows, ItemTab)
End Sub
Private Sub QueryBOMRowProperties(oBOMRows As BOMRowsEnumerator, ItemTab As Long)
    ItemTab = ItemTab + 3
    ' Iterate through the contents of the BOM Rows.
    Dim i As Long
    For i = 1 To oBOMRows.Count
        ' Get the current row.
        Dim oRow As BOMRow
        Set oRow = oBOMRows.Item(i)
        'Set a reference to the primary ComponentDefinition of the row
        Dim oCompDef As ComponentDefinition
        Set oCompDef = oRow.ComponentDefinitions.Item(1)
        Dim oPartNumProperty As Property
        Dim oDescripProperty As Property
        If Typeof oCompDef Is VirtualComponentDefinition Then
            'Get the file property that contains the "Part Number"
            'The file property is obtained from the virtual component definition
            Set oPartNumProperty = oCompDef.PropertySets _
                .Item("Design Tracking Properties").Item("Part Number")
            'Get the file property that contains the "Description"
            Set oDescripProperty = oCompDef.PropertySets _
                .Item("Design Tracking Properties").Item("Description")
            Debug.Print Tab(ItemTab); oRow.ItemNumber; Tab(17); oRow.ItemQuantity; Tab(30); _
                oPartNumProperty.Value; Tab(70); oDescripProperty.Value
        Else
            'The file property is obtained from the parent
            'document of the associated ComponentDefinition.
            Set oPartNumProperty = oCompDef.Document.PropertySets _
            Set oDescripProperty = oCompDef.Document.PropertySets _
            'Recursively iterate child rows if present.
            If Not oRow.ChildRows Is Nothing Then
                Call QueryBOMRowProperties(oRow.ChildRows, ItemTab)
            End If
        End If
    Next
    ItemTab = ItemTab - 3
End Sub
I made a simple modification in the "debug.print" area way at the end of the code. I added some code to write it into excel cells.
oWorkSheet.Range("B1").Value = oRow.ItemNumber
This works for these items. But.. at second I attempted to export the description like this:
Dim oDescripProperty As [Property]
'Get the file property that contains the "Description" oDescripProperty = oCompDef.Document.PropertySets_
.Item("Design Tracking Properties").Item("Description") oWorkSheet.Range("C" & y + i).Value = oDescripProperty
This result is NOT good, giving me this error when I run the code:
An unhandled exception of type 'System.Runtime.InteropServices.COMException' occurred in mscorlib.dll
Additional information: Exception from HRESULT: 0x800A03EC
What I think is wrong is: the [Property] type cannot be exported into Excel. Seems fair. Then I tried to get it as string but here i'm at a loss. This is waht i tried:
oWorkSheet.Range("C" & y + i).Value = oDescripProperty.ToString
Result in Excel:
System.__ComObject
So basicly my question is:
How can i convert my [Property] variable into a string?
Thank you for reading.
I hope that I can resolve this issue quickly 🙂
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
Replies (16)
Message 2 of 17
Jef_E
And the solution if found.. easy but didn't see it at first.
oWorkSheet.Range("C" & y + i).Value = oDescripProperty.Value
New question then.
In the API sample they use:
But in the API there is also mentioning for:
kPartNumberDesignTrackingProperties
How is this used? Can't seem to find a reference in the API
Inventor 2014 SP2
Message 3 of 17
BrandonBG
Anything that starts with a 'k' is an enumerator, or an identifier. It doesn't hold the iProperty value.
So, from the code,
 You could write it as
                   .Item("Design Tracking Properties").ItemByPropID(kPartNumberDesignTrackingProperties)
As far as I know, these should function the same way.
BrandonBG
Message 4 of 17
Jef_E
Thanks for the reply,
Well I think the line you provided fits better in my philosophy of coding, I try to use as less "between the quotes" as possible 🙂 So thank you for clarifying that out for me.
Which leads me to a next question, if you should want to open a file via the BOM how would I best go about this?
I'm currently using this line, this just gets the components full file name and then open it using the value.
Are there other options to do this? (Not that there is anything wrong with this I guess.)
oInvApp.Documents.Open(oCompDef.Document.FullDocumentName)
Inventor 2014 SP2
Message 5 of 17
BrandonBG
To open the file from the BOM, I think you have to identify the row, then open the referenced file:
oInvApp.Documents.Open(BOM.BOMView.BOMRow.ComponentDefinition.Document)
  Now, that line won't work as written, but that's how it's structured.
Brandon
Message 6 of 17
Jef_E
It's been a while..  had some urgent stuff that had a higher priority than this application..
I have got a new issue... When I export my BOM the order is based on the model data, and not on the structured list.
I'm using a code based on the programming help: "Using the BOM APIs API Sample"
What am I doing wrong? Why is this list not sorted as my BOM shows?
Source code:
Spoiler
Public Sub BOMQuery()
    Else
    End If
    Dim oBOM As BOM
    Else
    End If
    Dim ItemTab As Long
    ItemTab = -3
End Sub
    Dim i As Long
        Dim oRow As BOMRow
        Else
            End If
        End If
    Next
End Sub
My code: (the commented text is in dutch appolagies for this.
Spoiler
    ' Button click: BOM Export
    Private Sub INV_TOOL_BOM_EXPORT_Click(sender As Object, e As EventArgs) Handles INV_TOOL_BOM_EXPORT.Click
        ' Kopieren van template .xlsm file
        Dim oFileName As String
        oFileName = INV_TOOL_BOM_FILE_NAME.Text
        ' BOM export van hoofdassembly.
        ''  Controleren als het een hoofdassembly file is
        ' Excel file openen
        Dim oXL As Excel.Application
        Dim oWB As Excel.Workbook
        Dim oWS As Excel.Worksheet
        oXL = CreateObject("Excel.Application")
        oXL.Visible = True
        oWB = oXL.Workbooks.Open("C:\Users\jeee\Desktop\BOM Configurator R2.0.xlsm")
        oWS = oWB.Sheets("Overview")
        Dim oTitleRow As Integer
        oTitleRow = 5
        Dim oCurrentRow As Integer
        oCurrentRow = oTitleRow + 1
        ' Cells(Rij, Kolom)
        ' oWS.Cells(6, 2) = "Test"
        Call BOM_Query(oXL, oWB, oWS, oCurrentRow)
        oWB.Save()
        MsgBox("Finished")
    End Sub
    Private Sub BOM_Query(ByVal oXL As Excel.Application, ByVal oWB As Excel.Workbook, ByVal oWS As Excel.Worksheet, ByRef oCurrentRow As Integer)
        oDoc = oInvApp.ActiveDocument
        ' BOM openemen als referentie
        Dim oBOM As Inventor.BOM
        ' BOM levels instellen op alle niveaus
        ' BOM Structured view activeren ( moest dit niet het geval zijn, maar dit zou normaal niet kunnen)
        ' BOM gestructureerde lijst openemen als referentie
        Dim oBOMView As Inventor.BOMView
        Call BOMRow_Query_Properties(oBOMView.BOMRows, oXL, oWB, oWS, oCurrentRow)
    End Sub
    Private Sub BOMRow_Query_Properties(oBOMRows As Inventor.BOMRowsEnumerator, ByVal oXL As Excel.Application, ByVal oWB As Excel.Workbook, ByVal oWS As Excel.Worksheet, ByRef oCurrentRow As Integer)
        ' Loop door de BOM inhoud
        Dim i As Long
        ' Export instellingen
        Dim oFile As String
        oFile = "C:\Users\jeee\Desktop\BOM Configurator R2.0.xlsm"
            ' Opnemen van de huidige rij als referentie
            Dim oRow As Inventor.BOMRow
            ' Opnemen van het component dat overeenkomt met het item van rij (i)
            Dim oCompDef As Inventor.ComponentDefinition
            ' Properties verklaren
            Dim oDescriptionProp As Inventor.Property
            Dim oQTY As Integer
            Dim oItemNumber As String
            ' Controle Virtueel component
            If TypeOf oCompDef Is VirtualComponentDefinition Then
                ' Item nummer ophalen van virtueel component
                oItemNumber = oRow.ItemNumber
                ' Description ophalen van virtueel component
                oDescriptionProp = oCompDef.Document.PropertySets.Item("Design Tracking Properties").Item("Description")
                ' Aantallen ophalen van virtueel component
                oQTY = oRow.ItemQuantity
                ' Wegschrijven naar Excel Sheet
                oWS.Cells(oCurrentRow, 2) = oItemNumber
                oWS.Cells(oCurrentRow, 3) = oDescriptionProp.Value
                oWS.Cells(oCurrentRow, 4) = oQTY
            Else
            End If
            oCurrentRow = oCurrentRow + 1
                Call BOMRow_Query_Properties(oRow.ChildRows, oXL, oWB, oWS, oCurrentRow)
            End If
        Next
    End Sub
I made a screencast to properly show my problem.
Inventor 2014 SP2
Message 7 of 17
BrandonBG
Is the Excel sheet the structured BOM view in the incorrect order? Or is it the wrong BOM view?
Maybe you could resort the BOM view before exporting?
Brandon
Message 8 of 17
Jef_E
I tried resorting before i export, same result. As i compare the exported order with the diffrent BOMviews, I can say the exported BOMview is not the "structured" but the Model Data.
But in my code is stated:
So where do I go wrong?
Inventor 2014 SP2
Message 9 of 17
BrandonBG
This is a guess, but the issue may be inside *Private Sub BOMRow_Query_Properties*. Can you reset the BOMView as "Structured" inside this sub? I think the code is looking at the BOMRows in the Model View by default since the Model View is BOMView 1, and Structured View is BOMView 2. Brandon
Message 10 of 17
BrandonBG
Message 11 of 17
Jef_E
I have tried this but the result is the same. The BOMView is passed with the BOMrows? Kinda bummed that this is not working for me right now.
Inventor 2014 SP2
Message 12 of 17
BrandonBG
I'm still not sure you are specific enough in that sub.
Instead of:
Try
        For i = 1 To oBOM.BOMViews.Item("Structured").BOMRows.Count
            oRow = oBOM.BOMViews.Item("Structured").BOMRows.Item(i)
Brandon
Message 13 of 17
Jef_E
Nope.. Tried it, same result. Thanks for the input 🙂
I also retried just using the source code.. same result (maybe I had made some mistake reworking the code)
Source code result:
Spoiler
Item | Quantity | Part Number | Description |
1 | 1 | Pipe ø88,9 x 6,3 - lg. 427mm _ WN 1.4306 _ 3.1_ | Pipe ø88,9 x 6,3 - lg. 427mm
3 | 1 | Elbow 90deg DN80(ø88,9) x 3,2 - acc. DIN 2605 type 3_Steel | Elbow 90deg DN80(ø88,9) x 3,2 - acc. DIN 2605 type 3
4 | 1 | Pipe ø88,9 x 3,2 - lg. 161mm _ WN 1.4306 _ 3.1_ | Pipe ø88,9 x 3,2 - lg. 161mm
2 | 1 | Repad ø200 x 12mm (Plate 201 x 200) _ WN 1.4307 _ 3.1_ | Repad ø200 x 12mm (Plate 201 x 200)
6 | 1 | Hex Head Plug 1/4in - acc. ASME B16.11 - A2 | Hex Head Plug 1/4in - acc. ASME B16.11
5 | 1 | 61477-01_C-BW-1_Nozzle-006-Testplate | Plate ø110 x 5mm
Some input from Autodesk would be nice... or am I obligated to do a sorting in EXCEL? Seems to me that would be a LAST LAST resort. I believe it shoud export in the correct order from the structured list.
But I also done some digging. And found this.
In the source code is stated
When i follow the API using the search for "BOMView" I found this in the BOMViews Object.
Spoiler
BOMViews.Item PropertyParent Object: BOMViews
DescriptionReturns the specified BOMView object from the collection.
SyntaxBOMViews.Item( Index As Variant ) As BOMView
Parameters
NameDescription
IndexInput Variant value that specifies the BOMView to return. This can be either a numeric value indicating the index of the item in the collection or it can be a string indicating the name of a BOMView. If an out of range index or a name of a non-existent BOMView is provided, an error will occur.
Then I looked into the BOMView object.
Spoiler
BOMView.ViewType PropertyParent Object: BOMView
DescriptionProperty that returns the BOM View type. Possible return values are kModelDataBOMViewType (for the 'raw' view), kStructuredBOMViewType (for the structured view) and kPartsOnlyBOMViewType (for the parts-only view).
SyntaxBOMView.ViewType() As BOMViewTypeEnum
BOMViewTypeEnum Enumerator DescriptionBOM View types.
Methods
NameValueDescription
kModelDataBOMViewType62465The 'raw' view.
kPartsOnlyBOMViewType62467The parts-only View.
kStructuredBOMViewType62466The Structured View.
But these are not incorperated into the code. So I tried it my self but clearly I don't know how 😄
Try 1: Why can't you access the BOMView from the BOM?
        oBOMView = oBOM.BOMView.ViewType.kStructuredBOMViewType
An unhandled exception of type 'System.MissingMemberException' occurred in Microsoft.VisualBasic.dll
Additional information: Public member 'BOMView' on type 'BOM' not found.
Try 2: Kinda obvious error because I found the ViewType under "BOMView" and not "BOMViews"
        oBOMView = oBOM.BOMViews.ViewType.kStructuredBOMViewType
Additional information: Public member 'ViewType' on type 'BOMViews' not found.
But.. When I debug.print my bomview type it gives me the correct value 😞 WHY is this so frustrating?
62466
Inventor 2014 SP2
Message 14 of 17
Vladimir.Ananyev
BOMView.Export method uses the rows sequence inherited from the Model BOM view.
It does not depend on the sorting in the Structured BOM view.
You may verify it using the following test code:
Sub BOM_test()
    Dim oAsmDoc As AssemblyDocument
    Set oAsmDoc = ThisApplication.ActiveDocument
    Dim oAsmDef As AssemblyComponentDefinition
    Set oAsmDef = oAsmDoc.ComponentDefinition
    Dim oBOM As BOM
    Set oBOM = oAsmDef.BOM
    Set oBOMView = oBOM.BOMViews.Item("Structured")  'Structured
    Dim oBOMRow As BOMRow
    Dim oProp As Inventor.Property
    Dim oDoc As Inventor.Document
    Dim pn As String
    For Each oBOMRow In oBOMView.BOMRows
        Set oDoc = oBOMRow.ComponentDefinitions.Item(1).Document
        Set oProp = oDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number")
        pn = oProp.value
        Debug.Print oBOMRow.ItemNumber, oBOMRow.ItemQuantity, pn
    Next
  Call oBOMView.Export("c:\temp\AAA.xls", FileFormatEnum.kMicrosoftExcelFormat)       oAsmDoc.Update     Beep End Sub
You may consider several workarounds.
1) you may sort rows in the resulting Excel file
2) you may export BOMRow objects to the Excel file one-by-one in any desired order.
Sometimes it is very convenient to organize references to BOM rows in the temporary sorted .NET collection (e.g., SortedList) that allows you to implement any sorting logic:
https://msdn.microsoft.com/en-us/library/system.collections.sortedlist(v=vs.110).aspx
Cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Message 15 of 17
Jef_E
@Vladimir.Ananyev Like in this example?
So you could create a list like this
My list would look like this: (Left column beeing the BOMrow-ID, the right item-ID)
1   5
2   8
3   9
4   7
5   3
6   1
7   4
8   10
9   6
10  2
And then sort it so it looks like this?
6   1
10  2
5   3
7   4
1   5
9   6
4   7
2   8
3   9
8   10
So I can loop through the right column, which contains the correct export order, but export the corresponding row? Or did you mean something else?
Could you post a sample code to do this? I don't quite see it in the sample code on the MSDN site.
Inventor 2014 SP2
Message 16 of 17
NachoShaw
Hey
I know its not part of the problem but why dont you insert a new row in excel for every row of the BOM you add. you wouldnt need to format the grid then as the design format of the excel sheet would follow the inserted rows down.
StartRow = 1 'or whatever row your first bom line is
Rows(StartRow + 1 & ":" & StartRow + 1).Select
Selection.Insert Shift:=xlDown
Cheers
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Message 17 of 17
Jef_E
I'm currently not so worried about how I export the content from the BOM to Excel. There are alot of options that could be used.
My main concern is that the exported order is not correct. After I can be 100% sure the order for my export is correct I will go to the next step, but I will keep your comment in mind.
Inventor 2014 SP2
