Hi
Im posting a code here, im trying to set BIM pipe as like reference snip . can somebody help me to solve this problem.
Sub Main
Dim osm As AssemblyDocument = TryCast(ThisApplication.ActiveDocument, AssemblyDocument)
If osm IsNot Nothing Then
Dim oBIM As BIMComponent = osm.ComponentDefinition.BIMComponent
Dim oBimConnectors As BIMConnectors = oBIM.Connectors
' Prompt the user to select circular edges
Dim collGeo As ObjectCollection = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllCircularEntities, "Select circular edges")
' Check if the user selected any edges
If collGeo.Count > 0 Then
' Assuming you have a defined oBimConnDef somewhere in your code.
' Correct this assumption based on your actual code.
Dim oBimConnDefNew As BIMConnectorDefinition = oBIM.Connectors.CreatePipeConnectorDefinition(collGeo, BIMConnectorShapeEnum.kCircularShapeConnector)
MsgBox("Connector type: " & oBimConnDefNew.ConnectorType.ToString())
' Adding the newly created connector definition to the BIM component's connectors.
oBimConnectors.Add(oBimConnDefNew)
Else
MsgBox("No circular edges selected.")
Else
MsgBox("Active document is not an assembly document.")
End Sub
![sureshrext_1-1711540427989.png sureshrext_1-1711540427989.png](/t5/image/serverpage/image-id/1342511i8318CDD54713D223/image-size/medium?v=v2&px=400)
