Hello Autodesk Inventor Community,
I'm currently facing a challenge in my project. I have to manually input the "Item Qty" of individual parts because my assembly contains numerous parts, making it difficult to ensure accuracy in the title block data entry.
Similar to how other data like part number and description update automatically in the title block when drafting individual components, I also want the "Item Qty" to update automatically. The "Item Qty" data can be found in BOM > Parts Only > Item Qty.
I'm seeking an iLogic code solution that can copy the data of "Item Qty" from the Parts Only window of the BOM in the assembly and paste it into the component's custom properties. This way, before starting drafting, I can run this code to update the "Item Qty" in the parts, allowing me to place formulas to add custom properties in the title block.
Thank you very much for your assistance!
Hi @jaimin.ja.3 . There are already quite a few solutions to this problem. Here are some links: link , link , link , link .
Andrii Humeniuk - Leading design engineer
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
