Message 1 of 13
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
I`m trying to look into if it is possible to create a set of rules that makes me generate a HANDRAIL based on certain specifications from a 2D or 3D sketch...
I can make a profile(s) in the library for Frame Generator so that I get the rails and the kickplate form the Frame Generator.
What I want also is my code to insert a specific part in a corner based on the angle. Say that I have a 90 deg turn in the sketch, then I want to cut back from the corner say 150 mm in each direction and insert a part from the library named ex Corner90.ipt
Anyone know any tips for this or can point me in the direction of something ?
-Frank
