The task of placing a base view of each individual frame member is very repeatable. But can it be automated? Here is my process when creating the drawing for the frame members.
I am also experimenting with the BOM. I'm getting close to not needing the drawings at all, but to my knowledge, there's no simple way to convey the relative orientation of the cuts without a drawing.
What can I do to save time?
Inventor 2021, Windows
Solved by A.Acheson. Go to Solution.
Any suggestions? My drawing template and frame assembly is attached to the original post.
1-3 are possible with ilogic, and would be repeatable by running through the frame members.
4-5 are the tricky ones. You could dimension the one piece then loop through the other members but chances are it wouldn’t successfully hold the dimension in position especially where cuts and orientation are concerned.
Search for ilogic automated drawings run from the assembly environment. I have a sample, I can try dig out to do the drawing piece, but it doesn’t have the target frame member piece of the code.
Haven’t got inv2021 so maybe some screen shots would help as well.
Thanks for the input. I suppose I'll spend some time learning how to use iLogic.
Here is a simplified iLogic Rule since actually using ilogic first, you can see the benefits of learning immediately. Simply pasted it as external rule and open the document part or assembly you want to create a drawing for then run the rule. It is set up to just grab a drawing template but if you change this line to include where you save your default template it will use that. Simply remove the apostrophe ['] (uncomment) from the line it will turn black then adjust the file path. Then comment (add the apostrophe ['] 0 to the line below it to remove that from the rule.
'oDrawingDoc = ThisApplication.Documents.Add(kDrawingDocumentObject,C:\Temp\Templates\Standard.dwg,True)'Enter the file path of the template you want to use
External Rule,
Dim oDoc As Document Dim oDrawingDoc As DrawingDocument Dim oSheet As Sheet Dim oBaseView As DrawingView Dim oUOM As UnitsOfMeasure Dim oTG As TransientGeometry oTG = ThisApplication.TransientGeometry DWGcreate = MsgBox ("Would You Like To Create A Drawing From This Part/Assembly?" & vbLf & vbLf & "This Will Create a Base, Side & ISO View", vbYesNo, "User Prompt") If DWGcreate = vbYes Then oDoc = ThisApplication.ActiveDocument 'oDrawingDoc = ThisApplication.Documents.Add(kDrawingDocumentObject,C:\Temp\Templates\Standard.dwg,True)'Enter the file path of the template you want to use by replacing C:\Temp\Templates\Standard.dwg oDrawingDoc = ThisApplication.Documents.Add(kDrawingDocumentObject)'Default Drawing, no specific template oDrawingDoc.Activate() oDrawingDoc.Activate() oSheet = oDrawingDoc.Sheets.Item(1) oPoint1 = oTG.CreatePoint2d (12,15) 'Scale Choices Dim MyArrayList As New ArrayList MyArrayList.Add("1/40") MyArrayList.Add("1/30") MyArrayList.Add("1/20") oScale = InputListBox("Select one:", MyArrayList, "", "iLogic", "Scale Choices") 'oScale = InputBox("Enter Desired Scale", "Scaler", "1:1") 'oScale = InputBox("Enter Desired Scale - AS A DECIMAL", "Set Drawing Scale", "1") 'oScale = 1/20'1/3 If oScale = "1/40" Then oScale = 0.025 ElseIf oScale = "1/30" Then oScale = 0.0333333333 ElseIf oScale = "1/20" Then oScale = 0.05 End If oBaseView = oSheet.DrawingViews.AddBaseView(oDoc, oPoint1, oScale, ViewOrientationTypeEnum.kTopViewOrientation, DrawingViewStyleEnum.kHiddenLineDrawingViewStyle) Dim oRightView As DrawingView Dim oPoint2 = oTG.CreatePoint2d (25,15) Dim RightView = oSheet.DrawingViews.AddProjectedView(oBaseView,oPoint2,DrawingViewStyleEnum.kFromBaseDrawingViewStyle) Dim oIsoView As DrawingView Dim oPoint3 = oTG.CreatePoint2d (35,22) oSheet.DrawingViews.AddProjectedView(oBaseView,oPoint3,DrawingViewStyleEnum.kShadedDrawingViewStyle) dwgretrieve = MsgBox ("Would You Like To Dimension Drawing?" & vbLf & vbLf & "This will Retrieve The Dimensions on Base View", vbYesNo, "User Prompt") If dwgretrieve = vbYes Then oSheet.drawingdimensions.generaldimensions.retrieve(oBaseView) End If End If
Here is a link to an automated drawing from assembly. it took me a while to figure out how to make it all work. This one really has everything down to placing view, view labels etc.
I would keep the post open as other user may have completed frame generator specific rules and could help you out, it may just take some time.
External Rule,
I've created an automatic drawing program (with alot of help from a number of different threads) that works pretty well for creating drawings for assemblies with alot of sub parts, the generator runs through and creates multiple pages and places and dimensions the sub parts and assemblies automatically, including scaling.
You will need to edit line 31 to put in the link to your .idw template file.
Also, lines 43 to 46 which are the dimensions in cm to the borders of your drawing.
Seems to work fairly well and certainly speeds up my process! let me know if any help needed.
Good day. Is there a ilogic rule that can pull out overall dimensions (length and width ) of an assembly view in Inventor?Please help.
Thank you
Thank you
