Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Automate derive from .step file to single body .ipt file
8 REPLIES 8
Message 1 of 9
Daan_M
303 Views, 8 Replies
I have: A folder with 200 .step files of assemblies with multiple bodies.
I want: A folder with 200 .ipt files containing a single body.
How i go about this manually:
1. Import the .step file into Inventor, this results into a .iam file which i save in the same folder
2. Open a new .ipt file and use 'Derive', select the saved .iam i want and use option 'combine into one body'.
3. Break the derive link and save the .ipt file which now contains a single body
This is alot of clicking to repeat for 200 files.
Does anyone know a way to automate this?
8 REPLIES 8
Message 2 of 9
Andrii_Humeniuk
in reply to: Daan_M
Hi @Daan_M . Change the path to your template file (line 24).
Imports System.Windows.Forms
Sub main
	oInvApp = ThisApplication
	oProject = oInvApp.DesignProjectManager.ActiveDesignProject
	Dim sPathFolder As String = GetPathFolder(oProject.WorkspacePath)
	If String.IsNullOrEmpty(sPathFolder) Then Exit Sub
	Dim sFiles() As String = System.IO.Directory.GetFiles(sPathFolder & "\", "*.STEP")
	If sFiles.Length = 0 Then Exit Sub
    Dim oPB As Inventor.ProgressBar
	oPB = oInvApp.CreateProgressBar(False, sFiles.Length - 1, "Create parts from step files...")
    oPB.Message = ("Loading...")
	For i As Integer = 0 To sFiles.Length - 1
		Dim oNewAsmName As String = CreateAssemblyFromSTEP(sFiles(i))
		If String.IsNullOrEmpty(oNewAsmName) Then Continue For
		Call CreatePartDriveAsm(oNewAsmName, sFiles(i))
        oPB.Message = ("Create part from step file. Progress " & i & " of " & sFiles.Length - 1 & ".")
        oPB.UpdateProgress
	Next i
	oPB.Close()
End Sub
Dim oInvApp As Inventor.Application
Dim sTemplate As String = "\\Comp59\Work SP\Templates\ru-RU\КТВ_Деталь.ipt"
Private Function GetPathFolder(ByVal sPathStart As String) As String
	Dim Dialog = New FolderBrowserDialog()
	Dialog.SelectedPath = sPathStart
	If DialogResult.OK = Dialog.ShowDialog() Then
		Return Dialog.SelectedPath
	Return Nothing
End Function
Private Function CreateAssemblyFromSTEP(ByVal sPathFile As String) As String
	Dim oDoc As Document = oInvApp.Documents.Open(sPathFile, False)
	oDoc.Save()
	oDoc.Close(True)
	Return oDoc.FullFileName
End Function
Private Function CreatePartDriveAsm(ByVal oNewAsmName As String, ByVal sPathFile As String)
	Dim oDerivedAssemblyDef As DerivedAssemblyDefinition
	Dim oPDoc As PartDocument = oInvApp.Documents.Add(kPartDocumentObject, sTemplate, False)
	Dim oRefComps As ReferenceComponents = oPDoc.ComponentDefinition.ReferenceComponents
	oDerivedAssemblyDef = oRefComps.DerivedAssemblyComponents.CreateDefinition(oNewAsmName)
	oDerivedAssemblyDef.DeriveStyle = DerivedComponentStyleEnum.kDeriveAsMultipleBodies
	oDerivedAssemblyDef.IncludeAllTopLevelWorkFeatures = DerivedComponentOptionEnum.kDerivedExcludeAll
	oDerivedAssemblyDef.IncludeAllTopLevelSketches = DerivedComponentOptionEnum.kDerivedExcludeAll
	oDerivedAssemblyDef.IncludeAllTopLeveliMateDefinitions = DerivedComponentOptionEnum.kDerivedExcludeAll
	oDerivedAssemblyDef.IncludeAllTopLevelParameters = DerivedComponentOptionEnum.kDerivedExcludeAll
	Dim oDerivedAss As DerivedAssemblyComponent
	oDerivedAss = oRefComps.DerivedAssemblyComponents.Add(oDerivedAssemblyDef)
	Call oDerivedAss.BreakLinkToFile()
	oPDoc.SaveAs(System.IO.Path.ChangeExtension(sPathFile, "(Part).ipt"), False)
	oPDoc.Close(True)
End Function
Andrii Humeniuk - Leading design engineer
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
Message 3 of 9
Daan_M
in reply to: Andrii_Humeniuk
@Andrii_Humeniuk Thank you, great code, i restructed it a bit and changed some text for my case.
Sub Main
			MsgBox("geen folder geselecteerd")
			Exit Sub
'/// STEP ///
		Exit Sub
	oPB = oInvApp.CreateProgressBar(False, sFiles.Length - 1, "Parts aanmaken uit STP files...")
    oPB.Message = ("Even geduld...")
'		If String.IsNullOrEmpty(oNewAsmName) Then Continue For
		oPB.Message = ("Bezig met " & i & " of " & sFiles.Length - 1 & ".")
        oPB.UpdateProgress
	Next i
	oPB.Close()
End Sub
Dim sTemplate As String = "X:\CAD_3D\00 - Inventor standaard (NIET AANKOMEN)\Templates\Metric\Standard (mm).ipt"
	Try
	Return Nothing
	Catch
		Exit Function
	End Try
End Function
'	Try
		oDoc.Save()
		If oDoc.DocumentType = kPartDocumentObject Then
		Dim Svar As Integer = 1
		Return Svar
		oDoc.Close(True)
'	Catch
'		Exit Function
'	End Try
End Function
'Try
	oPDoc.SaveAs(System.IO.Path.ChangeExtension(sPathFile, "SIMPLIFIED.ipt"), False)
	oPDoc.Close(True)
'	Catch
'		Exit Function
'	End Try
End Function
I have two additional questions;
1. some of the .STEP files are translated to a Partdocument instead of an Assembly document. This causes a problem in the function below, since it expects the file to be an assembly and not a part.
 It would be ok to skip this function for the most part, and it just saved the partfile directly as is.
How can i best do this?
2. The output is a bit messy at the moment;
Green = original .STEP file in my folder
Blue = The folder Inventor creates when saving the translated .STEP file to a native assembly.
Red = The output i need
Yellow = All the parts from the assemblies after translation from .STEP
Yellow and Blue can be deleted i just need the orinals files (Green) and the output (Red) to be left in the folder
Message 4 of 9
Andrii_Humeniuk
in reply to: Daan_M
I wrote the code according to my template, but added your changes to it. In case, if an .ipt was created after converting the STEP file, it will be renamed to "SIMPLIFIED.ipt" if the ".iam" is followed by the old actions. Added DeleteDontNeedFile function to delete ".iam" folder.
Imports System
Sub main
	Dim sFiles() As String = IO.Directory.GetFiles(sPathFolder & "\", "*.STEP")
		Call CreatePartDrive(oNewAsmName, sFiles(i))
		Call DeleteDontNeedFile(oNewAsmName)
        oPB.UpdateProgress
	Next i
	oPB.Close()
	Shell("explorer.exe /Open," & sPathFolder, vbNormalFocus)
End Sub
	Return Nothing
End Function
	oDoc.Save()
	oDoc.Close(True)
End Function
Private Function CreatePartDrive(ByVal oNewAsmName As String, ByVal sPathFile As String)
	If IO.Path.GetExtension(oNewAsmName) = ".ipt" Then
		IO.Path.ChangeExtension(oNewAsmName, "SIMPLIFIED.ipt")
	Else If IO.Path.GetExtension(oNewAsmName) = ".iam" Then
		oPDoc.SaveAs(IO.Path.ChangeExtension(sPathFile, "SIMPLIFIED.ipt"), False)
		oPDoc.Close(True)
End Function
Private Function DeleteDontNeedFile(ByVal oNewAsmName As String)
		Dim sDirectory As String = IO.Path.GetDirectoryName(oNewAsmName)
		Try : IO.Directory.Delete(sDirectory, True)
		Catch : MessageBox.Show(sDirectory, "Failed to delete folder!") : End Try
End Function
 In my situation the Inventor put all the build files in one folder so all I had to do was delete the folder, if you have parts being created outside of the folder then let me know and I will make changes to the DeleteDontNeedFile function.
Message 5 of 9
Daan_M
This works perfectly, thank you!
Message 6 of 9
Daan_M
Hi @Andrii_Humeniuk,
I made a few slight adjustments, all parts get moved to the 'Outputs folder' now (red).
Problem: if the STEP/STP file contains a part, then a subfolder is created automatically by Inventor, the result part gets put in there, instead of the original path. So this part will remain in the subfolder (blue) and not moved to the 'Outputs' folder.
Full Code
Imports System
Sub main
	Dim oExtensions(1) As String
	oExtensions(0) = "*.STP"
	oExtensions(1) = "*.STEP"
	For Each Extension In oExtensions
	Dim sFiles() As String = IO.Directory.GetFiles(sPathFolder & "\", Extension)
	oPB = oInvApp.CreateProgressBar(False, sFiles.Length - 1, "Parts aanmaken & Solids hernoemen...")
        oPB.Message = ("Bezig met " & i + 1 & " of " & sFiles.Length & ".")
        oPB.UpdateProgress
	Next i
	'hier worden alleen parts aangepakt
	Dim iptFiles() As String = IO.Directory.GetFiles(sPathFolder & "\", "*.ipt")
	For i As Integer = 0 To iptFiles.Length - 1
		Dim oCleanNames As String = CleanNames(iptFiles(i))
	Next i
	oPB.Close()
Next
Dim OutputFolder As IO.DirectoryInfo = IO.Directory.CreateDirectory(sPathFolder & "\Outputs")
Dim AllPartFiles() As String = IO.Directory.GetFiles(sPathFolder & "\", "*.ipt")
For Each PartFile As String In AllPartFiles
	Dim Destination As String = OutputFolder.FullName & "\" & IO.Path.GetFileName(PartFile)
	IO.File.Move(PartFile, Destination)
Next
End Sub
	Return Nothing
End Function
Private Function CleanNames(ByVal sPathFile As String) As String
	Dim oDoc As Inventor.Document = oInvApp.Documents.Open(sPathFile, False)
		Dim oPCD As PartComponentDefinition = oDoc.ComponentDefinition
		Dim oFeature As PartFeature
		i = 1
		For Each oFeature In oPCD.Features
		oFeature.Name = "BodyReset" & i
		i = i + 1
		Next
		oDoc.Save()
		oDoc.Close(True)
End Function
	If oDoc.DocumentType = kAssemblyDocumentObject Then
		Dim i As Integer = 1
	Dim oAsmCompDef As AssemblyComponentDefinition = oDoc.ComponentDefinition
	Dim oOcc As ComponentOccurrence
	For Each oOcc In oAsmCompDef.Occurrences
		oOcc.Name = "BodyReset" & i
		i = i + 1
		Next
	oDoc.Save()
	oDoc.Close(True)
End Function
		IO.Path.ChangeExtension(oNewAsmName, ".ipt") 'Simplified
		oPDoc.SaveAs(IO.Path.ChangeExtension(sPathFile, ".ipt"), False) ' simplified
		oPDoc.Close(True)
End Function
	If IO.Path.GetExtension(oNewAsmName) = ".iam" Then ' simplified
		Catch : MessageBox.Show(sDirectory, "Kan folder niet verwijderen") : End Try
End Function
Message 7 of 9
Andrii_Humeniuk
in reply to: Daan_M
Hi @Daan_M . Unfortunately, I was unable to reproduce your situation. In my case, Assembly files are constantly being created. But I've optimized your code anyway, and added a line of code (79-81) that I hope will help you. It checks where the .ipt file is located and moves it if necessary.
Imports System
Sub Main
	Dim sFiles() As String = IO.Directory.GetFiles(sPathFolder & "\").Where(Function(s) {".STP", ".STEP" }.
							Contains(IO.Path.GetExtension(s))).OrderBy(Function(s) IO.Path.GetFileName(s)).ToArray()
	oPB = oInvApp.CreateProgressBar(False, sFiles.Length, "Parts aanmaken & Solids hernoemen...")
	oPB.UpdateProgress
		Dim oNewAsmName As String = CreateComponentFromSTEP(sFiles(i))
        oPB.UpdateProgress
	Next i
	oPB.Message = "hier worden alleen parts aangepakt"
	oPB.UpdateProgress
	Next
	oPB.Close()
End Sub
	Return Nothing
End Function
Private Function CreateComponentFromSTEP(ByVal sPathFile As String) As String
		For i As Integer = 1 To oAsmCompDef.Occurrences.Count
			oAsmCompDef.Occurrences(i).Name = "BodyReset" & i
		Next i
	Else
		For i As Integer = 1 To oPCD.Features.Count
			oPCD.Features(i).Name = "BodyReset" & i
		Next i
	oDoc.Save()
	oDoc.Close(True)
End Function
		If IO.Path.GetDirectoryName(oNewAsmName) <> sPathFile Then
			IO.File.Move(oNewAsmName, sPathFile & "\" & IO.Path.GetFileName(oNewAsmName))
		oPDoc.Close(True)
End Function
End Function
Message 8 of 9
Daan_M
Almost there, the code gives an error  "on line 81 in rule: Could not find a part of the path."
 which is on line:
To understand better i put in a msgbox before the error giving the file location and the desired location:
MsgBox("current location: " & oNewAsmName & "    desired location: " & sPathFile & "\" & IO.Path.GetFileName(oNewAsmName))
With result:
But the "ADM1.STP\" part needs to be left out.
I tried fixing it but my understanding of programming only goes so far 😅
Message 9 of 9
Andrii_Humeniuk
in reply to: Daan_M
My mistake, this should help you:
IO.File.Move(oNewAsmName, IO.Path.GetDirectoryName(sPathFile) & "\" & IO.Path.GetFileName(oNewAsmName))
Technology Administrators
