Autodesk Inventor iLogic to set active lighting style
PaulMunford
Autodesk Autodesk
Message 1 of 8
PaulMunford
Please could you help me to set the active lighting style with iLogic?
This code will get the active lighting style name, but I can't set the active lighting style - what am I missing?
Dim oAssy As AssemblyDocument = ThisApplication.ActiveDocument
Dim oLightStyleName As String
oLightStyleName = oAssy.ActiveLightingStyle.Name
MessageBox.Show(oLightStyleName, "Title")
'This line doesn't work
oAssy.ActiveLightingStyle.Name = "Grid Light"
P.S. I found this post on the manufacturing dev blog. I have converted it to iLogic, but it doesn't work for me 😞
http://adndevblog.typepad.com/manufacturing/2015/07/change-activelightingstyle.html
Sub ChangeLightingStyle()
  Dim doc As Document
  Set doc = ThisApplication.ActiveDocument
  Dim lss As LightingStyles
  Set lss = doc.LightingStyles
  ' Let's just use the first style
  ' InternalName: "1:Cool Light"
  doc.ActiveLightingStyle = lss("1:Cool Light")
End Sub
Paul Munford
Technical Onboarding Architect
Linkedin
Replies (7)
Message 2 of 8
AlexFielder
Hi @PaulMunford
Long time no see around these parts 😉
I ran your code and it worked the first time, but not after that in a newly created assembly file.
The reason for this is because you were changing the name (of the active lightingstyle) to the string you desired with this line, not changing the active lightingstyle to it:
I've knocked up this simple rule:
Dim lightingstyletochangeto As LightingStyle = oAssy.LightingStyles.Item("Grid Light")
If Not oAssy.ActiveLightingStyle.Name = lightingstyletochangeto.Name Then
	oAssy.ActiveLightingStyle = lightingstyletochangeto
	InventorVb.DocumentUpdate()
Else
	MessageBox.Show("We're already using the desired lighting style!")
Which appears on the surface to answer your question. When it runs however, the active lightingstyle on the "View" tab of the Inventor interface doesn't seem to update so there must either be:
  1. a bug OR
  2. a missing update function I haven't used to update the Inventor interface
I'm not sure which without further investigation.
Cheers,
Alex.
Message 3 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@PaulMunford,
Try below iLogic code to set lightstyle.
Dim doc As Document
Dim ls As LightingStyle
If doc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
oAssy = doc
ls = oAssy.LightingStyles.Item("Grid Light")
oAssy.ActiveLightingStyle = ls
Else If doc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
Dim oPart As PartDocument
oPart = doc
ls = oPart.LightingStyles.Item("Grid Light")
oPart.ActiveLightingStyle = ls
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 4 of 8
PaulMunford
It was so much easier when I could just stop by your desk 😉
Thanks very much for that - it's ideal. I understand now that I need to call it up as an item, not just change it's name. I need to get better at browsing the object model and understanding hat I can do with it 🙂
I will be back with my next question shortly - i'm sure!
Paul
Paul Munford
Linkedin
Message 5 of 8
PaulMunford
Awesome!
Thanks @chandra.shekar.g you anticipated my next task:)
My ultimate goal is to create an iLogic rule that will step through all files in an assembly, open the file, change the lighting style and save the file - to update the thumbnail.
Paul
Paul Munford
Linkedin
Message 6 of 8
AlexFielder
psuedo-code for that would be something like:
Sub Main()
dim stylename as string = "My Chosen Stylename"
For each doc as Document in ThisAssembly.AllReferencedDocuments
   If typeof doc is PartDocument then
      setPartLighting(stylename)
   else 'assembly
      setAssemblyLighting(stylename)
   end if
Next
End Sub
Sub SetPartLighting(Byval stylename as string)
 'copy in the answers from above and hope the magic smoke doesn't escape!
End Sub
Sub SetAssemblyLighting(Byval stylename as string) 'copy in the answers from above and hope the magic smoke doesn't escape! End Sub
Message 7 of 8
PaulMunford
That looks encouraging!
I had the error:
'AllReferencedDocments' is not a member of 'Autodesk.iLogic.Interfaces.iManagedAssembly' ?
So I changed it to:
ThisAssembly.Document.AllReferencedDocuments
The code runs - but it doesn't seem to work 😕
An additional question, would the part file actually need to be opened and saved to get the thumbnail to update?
Paul Munford
Linkedin
Message 8 of 8
AlexFielder
You saw the bit in my reply that said "pseudo-code" right? Smiley Wink Smiley LOL
The best thing you can do is share what code you have for me/others to see.
