Good morning, I work with the 2023 version of inventor. I want to try this code that I found in the forums, which is about saving in PDF and DXF using an IDW. However, when I run it I get this error.
this is the code:
Sub Main() Dim myDate As String = Now().ToString("yyyy-MM-dd HHmmss") myDate = myDate.Replace(":","") ' & " - " & TypeString userChoice = InputRadioBox("Defined the scope", "This Document", "All Open Documents", True, Title := "Defined the scope") UserSelectedActionList = New String(){"DXF & PDF", "PDF Only", "DXF Only"} UserSelectedAction = InputListBox("What action must be performed with selected views?", _ UserSelectedActionList, UserSelectedActionList(0), Title := "Action to Perform", ListName := "Options") Select UserSelectedAction Case "DXF & PDF": UserSelectedAction = 3 Case "PDF Only": UserSelectedAction = 1 Case "DXF Only": UserSelectedAction = 2 End Select If userChoice Then Call MakePDFFromDoc(ThisApplication.ActiveDocument, myDate, UserSelectedAction) Else For Each oDoc In ThisApplication.Documents If oDoc.DocumentType = kDrawingDocumentObject Try If Len(oDoc.File.FullFileName)>0 Then Call MakePDFFromDoc(oDoc, myDate, UserSelectedAction) End If Catch End Try End If Next End If End Sub Sub MakePDFFromDoc(ByRef oDocument As Document, DateString As String, UserSelectedAction As Integer) ' oPath = oDocument.Path ' oFileName = oDocument.FileName(False) 'without extension 'oDocument = ThisApplication.ActiveDocument oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _ ("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = ThisApplication.TransientObjects.CreateNameValueMap oDataMedium = ThisApplication.TransientObjects.CreateDataMedium oFullFileName = oDocument.File.FullFileName oPath = Left(oFullFileName, InStrRev(oFullFileName, "\")-1) oFileName = Right(oFullFileName, Len(oFullFileName)-InStrRev(oFullFileName, "\")) oFilePart = Left(oFileName, InStrRev(oFileName, ".")-1) 'oRevNum = oDocument.iProperties.Value("Project", "Revision Number") 'oDocument = ThisApplication.ActiveDocument ' If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then oOptions.Value("All_Color_AS_Black") = 0 oOptions.Value("Remove_Line_Weights") = 0 oOptions.Value("Vector_Resolution") = 400 oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets 'oOptions.Value("Custom_Begin_Sheet") = 2 'oOptions.Value("Custom_End_Sheet") = 4 ' End If 'get PDF target folder path 'oFolder = Left(oPath, InStrRev(oPath, "\")) & "PDF" oFolder = oPath & "\iLogic PDF's (" & DateString & ")" 'Check for the PDF folder and create it if it does not exist If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder) End If 'Set the PDF target file name oDataMedium.FileName = oFolder & "\" & oFilePart & ".pdf" 'Publish document If (UserSelectedAction = 1) Or (UserSelectedAction = 3) Then oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)'For PDF's End If If (UserSelectedAction = 2) Or (UserSelectedAction = 3) Then oDocument.SaveAs(oFolder & "\" & oFilePart & ".dxf", True) 'For DXF's End If 'oDocument.SaveAs(oFolder & "\" & ThisDoc.ChangeExtension(".dxf"), True) 'For DXF's '------end of iLogic------- End Sub
It should be noted that the code is not my author, I am only using it for practical purposes.
I would like to know if the PDFs can also be saved separately and not in batches. an example: I have an idw with 3 sheets and I would like to save them as:
sheet -1
sheet -2
sheet -3
I really appreciate the help
