Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Auto Sweep Pipe from sketch
3 REPLIES 3
rp
262 Views, 3 Replies
We now have a code to click a sketch and then click a 3d sketch line to sweep a pipe (see code below).
Is there a possibility to automate this.
Just clicking the rule to make the sweep (pipe) allong the 3d sketch.
The 2D sketch is a circle for the outside and a circle for the inside diameter.
The 3D sketch is a path from workpoint to workpoint.
Dim doc As PartDocument = ThisDoc.Document
Dim profile As Profile = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchProfileFilter, "Select profile")
Dim curve As Object = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketch3DCurveLinearFilter, "Select sketch line")
Dim features = doc.ComponentDefinition.Features
Dim path As Path = features.CreatePath(curve)
Dim sweepFeatures = features.SweepFeatures
Dim sweepDefinition = sweepFeatures.CreateSweepDefinition(SweepTypeEnum.kPathSweepType, profile, path, PartFeatureOperationEnum.kNewBodyOperation)
sweepFeatures.Add(sweepDefinition)
Thanks in advance,
Ricardo
3 REPLIES 3
FINET_Laurent
in reply to: rp
Hi @rp,
What exactly do you want to automate? The sketches creation ? Or just removing the manual selection?
What would the workflow look like?
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
rp
in reply to: FINET_Laurent
Hi @FINET_Laurent ,
The manual operation of clicking 1st the sketch and 2nd the 3D sketch.
What we want is, when we click the rule it will automaticly make the sweep of the pipe.
So you don't have to click on the both sketches for the sweep.
Kind regards,
Ricardo
FINET_Laurent
in reply to: rp
Hi @rp,
Asuming there is only one 2D sketch (for the profile), and there is only one 3D sketch (for the path), here is an exemple:
Dim PartCompDef As Inventor.PartComponentDefinition = doc.ComponentDefinition
Dim profile As Profile = PartCompDef.Sketches.Item(1).Profiles.AddForSolid()
Dim curve As Object = PartCompDef.Sketches3D.Item(1).SketchLines3D.Item(1)
Kind regards,
FINET L.
Technology Administrators
