Hi @romu51. Below is an iLogic rule you can try for that task. I have not tested it yet myself, so I am not 100% sure if it will work yet, because WorkSurface is not one of the object types listed that we can use as input into the DrawingView.DrawingCurves property to get its curves. If this fails, we may have to go an additional step (or few) deeper by exploring into the WorkSurface.SurfaceBodies property, if this is even possible.
oObj = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select a Drawing View.")
If IsNothing(oObj) OrElse (TypeOf oObj Is DrawingView = False) Then Exit Sub
Dim oView As DrawingView = oObj
oView.IncludeSurfaceBodies = True
Dim oSheet As Inventor.Sheet = oView.Parent
oModelType = oView.ReferencedDocumentDescriptor.ReferencedDocumentType
If oModelType <> DocumentTypeEnum.kPartDocumentObject Then
MsgBox("The view must be of a Part, not an Assembly, because only Parts have WorkSurfaces.",,"")
Exit Sub
End If
Dim oViewPDoc As PartDocument = oView.ReferencedDocumentDescriptor.ReferencedDocument
Dim oWSs As WorkSurfaces = oViewPDoc.ComponentDefinition.WorkSurfaces
If oWSs.Count = 0 Then
MsgBox("There were no WorkSurfaces found in the Part in the selected view.",,"")
Exit Sub
End If
Dim oObjCol As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
For Each oWS As WorkSurface In oWSs
Dim oDCurves As DrawingCurvesEnumerator = Nothing
Try : oDCurves = oView.DrawingCurves(oWS) : Catch : End Try
If IsNothing(oDCurves) OrElse oDCurves.Count = 0 Then Continue For 'skip to next oWS
For Each oDC As DrawingCurve In oDCurves
Dim oDCSs As DrawingCurveSegments = oDC.Segments
For Each oDCS As DrawingCurveSegment In oDCSs
oObjCol.Add(oDCS)
Next
Next
Next
If oObjCol.Count = 0 Then Exit Sub
Dim oDDoc As DrawingDocument = oSheet.Parent
Dim oLayer As Inventor.Layer = Nothing
Dim oLayerCreated As Boolean = False
Try
oLayer = oDDoc.StylesManager.Layers.Item("WorkSurface Curves")
Catch
oLayer = oDDoc.StylesManager.Layers.Item(1).Copy("WorkSurface Curves")
oLayerCreated = True
End Try
If oLayerCreated Then
oLayer.Color = ThisApplication.TransientObjects.CreateColor(255, 0, 0) 'Pure Red
oLayer.LineType = LineTypeEnum.kContinuousLineType
'oLayer.LineWeight = .01 'in centimeters
oLayer.Plot = True
oLayer.Visible = True
'oLayer.SaveToGlobal
End If
oSheet.ChangeLayer(oObjCol, oLayer)
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
