I am trying to assign a part sketch in a drawing to a specific layer but have been unable to find anything on how to do this. I have been able to turn the visibility of a part sketch on and off using a proxy. The problem is that you can't assign the sketch itself to a layer you have to select as edges first to assign the sketch to a specific layer. Is what I am trying to do possible? My thought was if there is anyway to, with iLogic, either select the sketch I want and then select its edges and assign it to a layer or create a drawing sketch based off of the part sketch and then assign the drawing sketch to a specific layer. Any help would be greatly appreciated.
mrsmithTYTMZ,
I've got a start here, but am having a little trouble with one of my lines (which I've underlined). I'm baffled as to why this won't work, so am hoping that someone smarter and wiser than I can shed some light on this. Anyway, it at least tells me when the drawing sketch is named the same as a layer, so I feel like I am on the right track. Hope this helps and have a most blessed day!
' Set a reference to the drawing document.
' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
' Set a reference to the active sheet.
Dim oActiveSheet As Sheet
oActiveSheet = oDrawDoc.ActiveSheet
' Create a Drawing View Object
Dim oDrawingView As DrawingView
Dim oDrawingSketch As DrawingSketch
Dim oSketchEntity As SketchEntity
Dim oLayer As Layer
For Each oDrawingView In oActiveSheet.DrawingViews
For Each oDrawingSketch In oDrawingView.Sketches
For Each oLayer In oDrawDoc.StylesManager.Layers
If oDrawingSketch.Name = oLayer.Name Then
MessageBox.Show(oDrawingSketch.Name & " sketch should be on the " & oLayer.Name & " layer", "Title")
For Each oSketchEntity In oDrawingSketch.SketchEntities
oSketchEntity.Layer = oLayer
Next
End If
Next
Next
Next
iLogicVb.UpdateWhenDone = True
Peace,
Pete
Yes you are on a right track but since you where in drawing document you need to activate the sketch environment to change the layer of sketch. So I've added a simple code which was underlined that might help you most.
Dim oLayer As Layer
oDrawingSketch.Edit
oDrawingSketch.ExitEdit
Next
End If
Next
Next
Next
If you find this was helpful for your query please accept it as solution / give a kudos
Cheers,
SK.
SK,
Brilliant! That was definitely the missing piece to my puzzle. I rewrote it slightly, so that the sketch wouldn't edit as often, but that is what I was missing. Here is the revised code below with SK's missing pieces. Hope this helps and have a most blessed day!
Peace,
Pete
Dim oLayer As Layer
oDrawingSketch.Edit
Next
End If
Next
Next
Next
Just as an example this is what I have to do to change the visibility of a model sketch....
Dim oDoc As DrawingDocument oDoc = ThisApplication.ActiveDocument Dim oActiveSheet As Sheet oActiveSheet = oDoc.ActiveSheet Dim oDrawingView As DrawingView oDrawingView = oActiveSheet.DrawingViews(3) Dim oRefDoc As AssemblyDocument oRefDoc = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument Dim oAssDef As AssemblyComponentDefinition oAssDef = oRefDoc.ComponentDefinition Dim oOcc As ComponentOccurrence oOcc = oAssDef.Occurrences(1) Dim oPart As PartDocument oPart = oOcc.Definition.Document Dim oDef As PartComponentDefinition oDef = oPart.ComponentDefinition Dim oSketch As PlanarSketch For Each oSketch In oDef.Sketches Dim oSketchProxy As PlanarSketchProxy oOcc.CreateGeometryProxy(oSketch, oSketchProxy) If oSketch.Name = "SK Back MTG Holes With Cutouts" Then oDrawingView.SetVisibility(oSketchProxy, True) End If Next
I have modified the code as per your requirement. Hope this will help you.
' Set a reference to the drawing document. ' This assumes a drawing document is active. Dim oDrawDoc As DrawingDocument oDrawDoc = ThisApplication.ActiveDocument ' Set a reference to the active sheet. Dim oActiveSheet As Sheet oActiveSheet = oDrawDoc.ActiveSheet ' Create a Drawing View Object Dim oDrawingView As DrawingView Dim oDrawingSketch As PlanarSketch Dim oSketchEntity As SketchEntity Dim oLayer As Layer Dim oPartDoc As DocumentDescriptor Dim oCd As ComponentDefinition For Each oDrawingView In oActiveSheet.DrawingViews Dim oReferencedDocument As DocumentDescriptorsEnumerator oReferencedDocument = oActiveSheet.Parent.ReferencedDocumentDescriptors For Each oPartDoc In oReferencedDocument For Each oCd In oPartDoc.ReferencedDocument.ComponentDefinitions For Each oDrawingSketch In oCd.Sketches For Each oLayer In oDrawDoc.StylesManager.layers If oDrawingSketch.name = oLayer.name Then MsgBox oDrawingSketch.name & " sketch should be on the " & oLayer.name & " layer", "Title" oDrawingSketch.Edit For Each oSketchEntity In oDrawingSketch.SketchEntities oSketchEntity.Layer = oLayer Next oDrawingSketch.ExitEdit End If Next Next Next Next Next iLogicVb.UpdateWhenDone = True
If you find this was helpful please accept this as solution /Press the kudos button
Cheers,
SK.
@Anonymous Thank you for you help on this. We're close but I'm getting an error right after I close the message box:
Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
and this in the More Info tab:
System.Runtime.InteropServices.COMException (0x80004005): Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.SketchEntity.set_Layer(Layer )
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
it looks like the error is in the last For Loop.....I think...... If I comment out the line "oSketchEntity.Layer = oLayer" then the rule continues on and I get the message box that pops up about 15 times.
I hope I'm not being to much of a pain but could I ask for a slight change? 99 percent of my drawing views have Assemblies in them and the Sketches that I want to assign to a layer are in a part in said assembly. Also I would like to specify the name of the sketch (If oSketch.Name = "Skatch Name" and the name of the layer (oLayer.Name = "Layer Name") as the sketches are not named the same as the layers.....is this possible?
Thanks again....you don't realize how much easier this will make my job. 🙂
Can anyone explain why I would be getting this error when I use the code that @Anonymous posted. I have tried it on a few different parts and I get the same thing so I'm not sure what is wrong. Any help would be very much appreciated.
I talked with someone that said for what I'm trying to do the code that @Anonymous posted would not work as it is for drawing sketches only and I am trying to change the layer of a sketch imported from a part. They told me to look at the ChangeLayer method however I get nothing we I search for this method. Does anyone have any insight on this and willing to help me out. Many thanks.....
Just a bump to see if there is anyone that could help me with this problem.
Maybe this helps, if still needed...
Dim oDoc As DrawingDocument oDoc = ThisApplication.ActiveDocument Dim oActiveSheet As Sheet oActiveSheet = oDoc.ActiveSheet Dim oDrawingView As DrawingView oDrawingView = oActiveSheet.DrawingViews(1) 'View of Sheet Dim oRefDoc As AssemblyDocument oRefDoc = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument Dim oAssDef As AssemblyComponentDefinition oAssDef = oRefDoc.ComponentDefinition Dim oOcc As ComponentOccurrence oOcc = oAssDef.Occurrences(2) 'Assembly in sheet Dim oPart As PartDocument oPart = oOcc.Definition.Document Dim oDef As PartComponentDefinition oDef = oPart.ComponentDefinition Dim oSketch As PlanarSketch For Each oSketch In oDef.Sketches Dim oSketchProxy As PlanarSketchProxy If oSketch.Name = "SK Back MTG Holes With Cutouts" Then oOcc.CreateGeometryProxy(oSketch, oSketchProxy) oDrawingView.SetVisibility(oSketchProxy, True) ######### Set Lines As DrawingCurves And Set Layer ############# Dim oNewLayer As Layer oNewLayer = oDoc.StylesManager.Layers.Item("MyLayer Change Me") ' Get the TransientsObjects object to use later. Dim transObjs As TransientObjects transObjs = ThisApplication.TransientObjects Dim drawcurves As DrawingCurvesEnumerator drawcurves = oDrawingView.DrawingCurves(oSketchProxy) If Err.Number = 0 Then On Error GoTo 0 ' Create an empty collection. Dim objColl As ObjectCollection objColl = transObjs.CreateObjectCollection() ' Add the curve segments to the collection. Dim drawCurve As DrawingCurve For Each drawCurve In drawcurves Dim segment As DrawingCurveSegment For Each segment In drawCurve.Segments objColl.Add segment Next Next ' Change the layer of all of the segments. oDrawingView.Parent.ChangeLayer(objColl, oNewLayer) End If ################## End If Next
If want it for more than a special view or part, I would recoment to change it to an "for each" code.
Hi Pete,
Your code works really well and is what I am after (altering a sketch in a drawing document).
I was wondering if you where able to tweak it a little...?
Firstly I should give you a little bit more info about my drawing...
My .idw drawing has multiple sheets
On each sheet, within the first view, I have a sketch called "Workpiece size" which contains geometry on a layer called "Workpiece size"
tweaks...
1) I want to loop your code through all sheets within the drawing
2) I want to move all geometry within the sketch "Workpiece size" to a new layer
3) I want the new layer name to be set per sheet based on a Prompted Entry within each sheet.
For example...
On sheet 1 the Prompted Entry '{Item.Thickness}' = 18. I want to move the geometry within the sketch "Workpiece size" to a new layer called 'XLYP1H18'
On sheet 2 the Prompted Entry '{Item.Thickness}' = 13. I want to move the geometry within the sketch "Workpiece size" to a new layer called 'XLYP1H13' ('XLYP1H' will always be the same. the numer at the end will come from the 'Prompted Entry')
I have found some code that extracts the 'Prompted Entry' thanks to cadlinecommunity below.
Thanks in advance to any help you can give to either or all of the 3 questions
Regards
Mike
On Error Resume Next
Dim oSheet As Sheet
Dim oPromptEntry
Dim oCurrentSheet
oCurrentSheet = oDoc.ActiveSheet.Name
i = 1
For Each oSheet In oDoc.Sheets
'i = i+1
ThisApplication.ActiveDocument.Sheets.Item(i).Activate
oTitleBlock=oSheet.TitleBlock
oTextBoxes=oTitleBlock.Definition.Sketch.TextBoxes
For Each oTextBox In oTitleBlock.Definition.Sketch.TextBoxes
Select oTextBox.Text
Case "{Item.Thickness}"
oPromptEntry = oTitleBlock.GetResultText(oTextBox)
iProperties.Value("Custom", "layer name")=oPromptEntry
End Select
Next
Next
******Your original code*********
Dim oLayer As Layer
oDrawingSketch.Edit
Next
End If
Next
Next
Next
