Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Assembly SelectSet - Get component name
4 REPLIES 4
bryan_schmuland
176 Views, 4 Replies
I would like to select a plane or planes in an assembly document, and get the name of both the plane and the component it belongs to.
I have found some code which lets me get the name of the selected object (the plane) but from this I haven't been able to find out how to get the component name.  My end goal is to take the selected plane and apply a constraint.
Dim oAD As AssemblyDocument
Dim oSelected As SelectSet
oAD = ThisApplication.ActiveDocument
oSelected = oAD.SelectSet
For Each item In oSelected
   MessageBox.Show(item.name & " - " )
Next
4 REPLIES 4
Hi @bryan_schmuland
Give this a try.
For Each item As ComponentOccurrence In oSelected
Next
I was working on it at the same time apparently, so I will go ahead and post what I have too. 😁
Sub Main
	Dim oADoc As AssemblyDocument = TryCast(ThisDoc.Document, Inventor.AssemblyDocument)
	If oADoc Is Nothing Then Return
	Dim oSS As SelectSet = oADoc.SelectSet
	If oSS.Count = 0 Then Return
	Dim oSelected = oSS.Item(1)
	If TypeOf oSelected Is WorkPlaneProxy Then
		Dim oWPP As WorkPlaneProxy = oSelected
		Dim sWPName As String = oWPP.NativeObject.Name
		Dim oOcc As ComponentOccurrence = oWPP.ContainingOccurrence
		Dim sOccName As String = oOcc.Name
		MsgBox("Component Name = " & sOccName & vbCrLf & _
		"WorkPlane Name = " & sWPName)
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
This is great! Thanks
I realized just after posting my code above, that most of the variables you would want to be working with are all defined within the If...Then statement, so would not be available outside of that block of code.  Here is a better version of that code that minimizes that block of code, and leaves you with usable variables afterwards.
Sub Main
		MsgBox("An assembly was not obtained, so exiting rule.", vbCritical, "iLogic")
		'Logger.Debug("An assembly was not obtained, so exiting rule.")
		Return
		MsgBox("Nothing was pre-selected.", vbCritical, "iLogic")
		'Logger.Debug("Nothing was pre-selected.")
		Return
	Dim oWPP As WorkPlaneProxy = Nothing
	If TypeOf oSS.Item(1) Is WorkPlaneProxy Then oWPP = oSS.Item(1)
	If oWPP Is Nothing Then
		MsgBox("Pre-selected object was not a WorkPlaneProxy.", vbCritical, "iLogic")
		'Logger.Debug("Pre-selected object was not a WorkPlaneProxy.")
		Return
End Sub
Wesley Crihfield
Technology Administrators
